Amphib Moose
rickjohnson
Amphib Moose
Post by rickjohnson » Sat Feb 18, 2012 10:48 am
What is the height of a moose on amphib floats? (for a hanger door opening)
Rick
SR277
Kevin Brennan
Amphib Moose
Post by Kevin Brennan » Sat Feb 18, 2012 10:48 am
Good question I need to know also
rickjohnson@dcsol.com wrote:What is the height of a moose on amphib floats? (for a hanger door opening)
Rick
SR277
robert@montanasky.us
Amphib Moose
Post by robert@montanasky.us » Sat Feb 18, 2012 10:48 am
If on MFC 3500's, better have a 12' opening.
Bob 612e
Original Message:
Date: Thu, 11 Aug 2005 06:50:08 -0700 (PDT)
Subject: Re: Amphib Moose
ts?
Rick
SR277
mail2web - Check your email from the web at
http://mail2web.com/ .
Don Boardman
Amphib Moose
Post by Don Boardman » Sat Feb 18, 2012 10:48 am
Hi Rick,
Our Moose on Aerocet 3400 amphibs stands a bit over 12 ft.
Don B.
Reply-To: rebel-builders@dcsol.com
Rick
SR277
pollock
Amphib Moose
Post by pollock » Sat Feb 18, 2012 10:48 am
How are you guys lifting up the Moose for the float change over,where are
the lifting points and hardware ridging you need ?
Bill Pollock
Moose 244
From: "Kevin Brennan" <kevinjbrennan@sbcglobal.net>
Sent: Thursday, August 11, 2005 9:50 AM
Rick
SR277
pollock
Amphib Moose
Post by pollock » Sat Feb 18, 2012 10:51 am
I should have mentioned tail wheel into my question and maybe I would have
received replies !
Bill
M-244
Sent: Thursday, August 11, 2005 11:11 AM
Bill Pollock
Moose 244
Rick
SR277
Al Paxhia
Amphib Moose
Post by Al Paxhia » Sat Feb 18, 2012 10:51 am
Bill,
I am using a strap around each or the front wing attach brackets. The straps
are attached to spreader bar and a hoist. With my engine the airplane is
tail heavy so I also use a tail stand.
Al
Sent: Friday, August 12, 2005 8:38 AM
received replies !
Bill
M-244
Bill Pollock
Moose 244
Rick
SR277
pollock
Amphib Moose
Thanks Al for your input
Bill
M-244
Sent: Friday, August 12, 2005 12:40 PM
Bill,
straps
Al
received replies !
Bill
M-244
are
Bill Pollock
Moose 244
Amphib Moose
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:51 am
Bill, as Al has mentioned this is also how I do it as well...but I use two
chain falls for the front and a walk behind pallet truck for the tail. I put
a AN6 Bolt under the fuselage forward wing attach "stubs" to attach a short
cable with thimble loops on each end. One thimble ahead and one thimble
behind the "stub" on the AN6 bolt and the wing attach bolt keeps things from
sliding anywhere.
Sent: Friday, August 12, 2005 1:12 PM
Bill
M-244
Bill,
straps
Al
have
received replies !
Bill
M-244
Amphib Moose
Post by robert@montanasky.us » Sat Feb 18, 2012 10:51 am
Bill,
Install your forward wing attach bolts backwards (with the nut toward the
front). When you need to hang the plane, de-nut the bolt and slip on (a
nd
re-nut the bolt of course) a 4130 strap (1-1/2" x 5" x 3/16" thick) with
two holes - one for the wing attach bolt and one for a shackle pin. Mak
e a
cradle, spreader bar ... whatever you want to call it, such that on
bottom there are two shackles at the ends that mate and pick up the two
forward wing bold straps and at the top in the center is where the ceiling
hoist hooks up. The tail will be heavy as the pick-up points are way
forward of the CG ... but two men and a boy can lift it onto a tall
jack
stand. Make the tail jack stand such that it can be pinned at various
heights. Hope this helps.
Bob 612e
Original Message:
Date: Fri, 12 Aug 2005 11:38:29 -0400
received replies !
Bill
M-244
e
Bill Pollock
Moose 244
Rick
SR277
