sharpie markers
Jones, Michael
sharpie markers
Post by Jones, Michael » Sat Feb 18, 2012 10:48 am
hi all
quick tip i have discovered from ad on TV
many times i want to mark a hole or edge to cut or something but the part
was in a confined space and the marker i was using, sharpie, was to long to
get in and so had to mark surface in another way, well now sharp sells mini
sharpie markers, they are less that 1/2 length of regular sharpie, have some
of these already, good to keep several in shop just in case
regards
mike jones#007
sharpie markers
Post by Drew Dalgleish » Sat Feb 18, 2012 10:51 am
At 08:05 AM 8/11/2005 -0400, you wrote:
hi all
regards
mike jones#007
Good tip Mike I just bought 2 of these as soon as I saw them at the home
depot check out $0.99 each. They're very sharp too.
Brian Breathnach
sharpie markers
Post by Brian Breathnach » Sat Feb 18, 2012 10:51 am
I picked a couple also and then found that the mark is almost impossible to
get off the material. So, just wondering if the mark that cant be got off
might become corrosive over time?
Brian 779R
Sent: Thursday, August 11, 2005 8:49 PM
Subject: Re: sharpie markers
hi all
mini
some
regards
mike jones#007
mike.davis
sharpie markers
Post by mike.davis » Sat Feb 18, 2012 10:51 am
I always found sharpie marks came right off with a little acetone.
On 8/11/2005 8:55 PM, REBEL-BUILDERS@DCSOL.COM wrote to MIKE DAVIS:
-To: <mike.davis@dcsol.com>
-> I picked a couple also and then found that the mark is almost impossible
-> get off the material. So, just wondering if the mark that cant be got off
-> might become corrosive over time?
-> Cheers
-> Brian 779R
Bruce Uvanni
sharpie markers
Post by Bruce Uvanni » Sat Feb 18, 2012 10:51 am
Return Receipt
Your Re: sharpie markers
document:
was Bruce Uvanni/Burlington/IBM
received
by:
at: 08/12/2005 09:20:48
