I went out this morning to follow Wayne's advice and put a couple of
hours on the engine. The engine fired up normally, but after about 10
seconds there was a loud crack and the engine quit. On investigation it
appears that the idler gear and the camshaft gear are no longer in mesh.
It's hard to see, but I suspect there are a few teeth missing from the
latter. Anyway, the engine is now out and will go back for warranty
repair on Monday. Not bad for 0.8 hrs TTSN.
I suppose it could have happened at 200' on takeoff!
Al
Major Setback C-FGAH
Al,
Sorry to hear about your engine it will be interesting to hear what actually
happened. Please keep us informed.
Your right about the "it could be worse"
Brad (R195)
-> I went out this morning to follow Wayne's advice and put a couple of
-> hours on the engine. The engine fired up normally, but after about 10
-> seconds there was a loud crack and the engine quit. On investigation it
-> appears that the idler gear and the camshaft gear are no longer in mesh.
-> It's hard to see, but I suspect there are a few teeth missing from the
-> latter. Anyway, the engine is now out and will go back for warranty
-> repair on Monday. Not bad for 0.8 hrs TTSN.
-> I suppose it could have happened at 200' on takeoff!
-> Al
Brad (R195)
-> Al
At least it didn't happen at hour 24.5 You'll have to start your test
period over again. Hopefully it will be fixed quickly and you'll be back in
bussiness.
bussiness.
DrewI went out this morning to follow Wayne's advice and put a couple of
Al
That's a good attitude to handle bumps in the road .Congrads on your
completion
Bill Pollock
Sent: Friday, June 24, 2005 6:14 PM
Subject: Major Setback C-FGAH
completion
Bill Pollock
Al
