trimtab
bscheube
trimtab
Post by bscheube » Sat Feb 18, 2012 10:38 am
Scott,
I have finished the rudder trim tab and am ready to close it up. I just found
your website (looks really good Ted told me you were the real craftsmen when
it came to working with the moose now I can see that for myself.) I have
another question on your rudder trim you have a fairing(?) over the pushrod
of the servo. Is this somthing you manufactured? and did you also put one on
the elevator?(I did not see one in your elevator pictures) If you did
manufacture what are the dimensions and what size aluminum did you use (if you
can remember). Thanks again for the help Scott. I will send you a couple
pictures of my rudder trim and seawing mods that I put together if your
interested.
Bob Scheuber Moose/191
Dale Fultz
trimtab
Post by Dale Fultz » Sat Feb 18, 2012 10:38 am
What is the website??? Thanks Dale
Sent: Friday, June 10, 2005 8:39 AM
Subject: trimtab
Scott,
found
when
pushrod
on
you
interested.
bscheube
trimtab
http://www.goflyamoose.com/
Bob moose/191
-> What is the website??? Thanks Dale
-> ----- BobOriginal Message -----
-> From: <bscheube@dcsol.com>
-> Sent: Friday, June 10, 2005 8:39 AM
-> Subject: trimtab
-> > Scott,
-> > I have finished the rudder trim tab and am ready to close it up. I just
-> > found
-> > your website (looks really good Ted told me you were the real craftsmen
-> > when
-> > it came to working with the moose now I can see that for myself.) I have
-> > another question on your rudder trim you have a fairing(?) over the
-> > pushrod
-> > of the servo. Is this somthing you manufactured? and did you also put one
-> > on
-> > the elevator?(I did not see one in your elevator pictures) If you did
-> > manufacture what are the dimensions and what size aluminum did you use
(if
-> > you
-> > can remember). Thanks again for the help Scott. I will send you a couple
-> > pictures of my rudder trim and seawing mods that I put together if your
-> > interested.
-> > Bob Scheuber Moose/191
-> > List archives located at: https://www.dcsol.com/login
Kevin Brennan
trimtab
Post by Kevin Brennan » Sat Feb 18, 2012 10:38 am
How do we get to his website?
bscheube@dcsol.com wrote:Scott,
interested.
