High temps - Lycoming on Rebel
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:38 am
As my son even pointed out to me a few minutes ago.....allowing for altitude
and after a search of the lyco site
"209F if you're flying high enough to miss cell towers! Lycoming even says
220 in cruise is fine."
http://www.lycoming.textron.com/support ... peration/l
eaningEngines.html
. For engine longevity they suggest the following:
8. For maximum service life, maintain the following recommended limits for
continuous cruise operation:
(a) Engine power setting - 65% of rated or less.
(b) Cylinder head temperatures - 400oF. or below.
Neil Hardie
Post by Neil Hardie » Sat Feb 18, 2012 10:38 am
Go away from the computer for 15 minutes and Wayne comes back with even
more info. Amazing. Thanks again.
Neil
Sent: Monday, June 06, 2005 7:22 PM
Subject: Re: High temps - Lycoming on Rebel
** Check your subject, does it still reflect the message? **
altitude and after a search of the lyco site
says 220 in cruise is fine."
http://www.lycoming.textron.com/support ... ts/operati
on/l
eaningEngines.html
. For engine longevity they suggest the following: ................. 8.
C Oil temperature - 165oF. - 220oF
Now consider these temps are no problem if you keep below 65% power..but
who does..always around 75 or so dragging a set of floats from lake to
lake.
Sent: Monday, June 06, 2005 7:06 PM
Subject: RE: High temps
Thanks Wayne all good stuff as usual. Notice how I got this out before
you went north! You got the right Bob - I will check with him about
the Vernatherm and maybe not get so uptight about uptemp!!
Neil
Sent: Monday, June 06, 2005 5:41 PM
To me 215 is perfect (but I don't get much support on that opinion
around here)! Water boils at 212! 225 in climb is getting warm, but
not uncommon or dangerous. You're right though it's only going to get
higher on a day like today or yesterday that hit 32. Your CHT's sound
good although I do shoot for 350 to 375...but will take up to 425
continuous in cruise. If I remember right Bob had a Vernatherm issue
once with it sticking open..ie when heated it didn't lengthen and plug
the hole and force oil thru the cooler...so that's another thing to
check (and I may have the person wrong,,,,but it was someone here).
Oil cooler orientation is another variable as to how well it cools as
well, and how many kinks are in the 3" scat hose getting to it. Do the
cowl bottom doors have a lip on them? If not try giving them a bend
down. Did that on mine when I had the O-235 in it with no cooler that
ran 235/245 everyday without skipping a beat. The lip dropped the
temps about 10*F
Sent: Monday, June 06, 2005 5:06 PM
Subject: High temps
My Rebel ( read Bob Johnson's original #652 ) has taken to the air
for
the first time from the water. Since we put the floats on I have had
problem with high oil temps. They are running as high as 225 in
climb and even at 2200 rpm cruise they are around 215. With the
floats you expect higher temps because of the lower speeds and
higher work load on the engine but these are still too high running
at 2300 rpm.OAT's were running around 24 so not really hot - yet. I
have an 0-320 H engine. All lines to the oil cooler are good. We
have checked the timing ( cause of earlier high temps) and the oil
temp guage itself. Both are fine.The CHT's are running under 400
except for #2 which is running just over 400. EGT's are all close to
1200. Most 0-320 Cessna's use a 4" hose to the cooler and GIWH has a
3". Also we may open up the bottom end of the cowling to get more
air flow. Any ideas?
Neil Hardie
List archives located at: https://www.dcsol.com/login username
"rebel" password "builder" Subscription services located at:
Post by Walter Klatt » Sat Feb 18, 2012 10:38 am
Good to hear about another Rebel on floats. I used to have a
problem on mine, but it was much more severe than you describe.
My solution was to open the bottom more, and a year ago I also
opened my inlets a bit, and that totally solved my problem. Now I
can cruise in the hottest weather with CHT's below 400 and no
more step climbing to stay below 450. I never did have a problem
with oil temps as my cooler is mounted on the rear right baffle.
But in your case, Neil, sounds like you are just a tad high with
both oil and CHT's so maybe just opening the bottom cowl a bit
and adding that lip there, will fix both for you. The other thing
some people have done is faired the lower firewall flange which
helped too. On my old cowl (before opening the inlets), I also
riveted on a lexan eyebrow on the left inlet, and that seemed to
help as well.
[quote]-----Original Message-----
Sent: Monday, June 06, 2005 4:22 PM
http://www.lycoming.textron.com/support/publications/ke
yReprints/operation/l
eaningEngines.html
Yah, I do need to get a life!!! Working on it come Sunday!! LOL ! :O))
Sent: Monday, June 06, 2005 7:56 PM
Subject: RE: High temps - Lycoming on Rebel
Neil
