spring gear inserts too long?
Dan Morehouse
Post by Dan Morehouse » Fri Feb 17, 2012 5:27 pm
Thanks, Lonnie!
I must have been pretty tired when I couldn't see the easy way out. For some reason I was thinking there was a bolt to go at the bottom outside and not just the top outside corner.
I mentioned another web site. I thought somebody had one up the last few months on MSN where you could upload stuff to. I couldn't find it in these here archives. Was I dreaming?
Post by Mike Davis » Fri Feb 17, 2012 5:27 pm
You're not dreaming... If you go to my website, there is a page for links...
the site you are looking for is listed there. Also, I've still got Lonnie's
photos sitting on my desk! Sorry, but just haven't had time to scan them.
I don't have my own scanner, so I have to use one in another office, and the
only time I've gone to use it the system was already in use. I'll check
back on that soon though.
Sent: Monday, October 18, 1999 1:48 AM
Subject: re: spring gear inserts too long?
Thanks, Lonnie!
