Flap Handle & landing
Ted Waltman
Post by Ted Waltman » Sat Feb 18, 2012 10:35 am
Hello Rick,
Say, I too have heard that dumping the flaps right at touchdown can kill
lift, prevent bounce and make braking more effective. On the other
hand, an old time tailwheel instructor told me that someday, when you
take that split second to dump flaps, you might not be as on top of the
landing as you otherwise would be--and that's when it is going to bite
you with a ground loop. I'm not criticizing your or anyone else's
technique...just providing food for thought that was shared with me
once.
Rick Harper
Sent: Friday, June 03, 2005 5:09 PM
Subject: Re: Flap Handle
G'day from OZ !
I used a 1" OD pipe (it fits nicely into your hand) .....
The handle is a GREAT improvement ! ... (not boasting tooooo much here
:o)
I can come in on FULL flap (positive obviously) ... let her flare ...
and the INSTANT the wheels touch - I give her FULL negative flap ..
result NO BOUNCE !!! - (makes you look like you really know what you are
doing :o) :o) :o)
Rick Harper
541R
PS - Make sure you are using the LONGER handle (about 10 or 12 inches
from pivot to handle) ... the first one worked well - but was too short
& required 2 hands to get into negative / reflexed position in flight
.... the longer one can be done with one hand.
Sent: Friday, June 03, 2005 4:51 AM
Subject: Flap Handle
Is anyone using Rick Harper's flap handle? Is the the one inch
aluminum
pipe used 1 inch O.D or one inch I.D.?
A Hewko
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:35 am
I do the same as Rick does, on gusty days. If you need to come in a little
hot to get her to the ground the airplane then wants to float or will
balloon. If it decides to balloon and go around/runway length is getting too
late, I throw into full reflex. I remember the first time I did it from
about 3 feet up and said out loud to myself "this is going to hurt", but all
it did was paste the airplane firmly to the grass and rolled out nicely. I
use it quite a bit now on anything but calm days. Doesn't take much of a
gust to lift a Rebel wing...which is more likely to cause a ground loop if
unchecked than the quick throw of the flap handle into reflex (once it
becomes second nature at least and your not looking for the handle).
Sent: Friday, June 03, 2005 11:40 PM
Subject: RE: Flap Handle & landing
Hello Rick,
once.
Rick Harper
G'day from OZ !
:o)
doing :o) :o) :o)
Rick Harper
541R
aluminum
A Hewko
Rick Harper
Post by Rick Harper » Sat Feb 18, 2012 10:35 am
G'day Ted !
I appreciate you input .... and I'll make sure I don't let that
happen !
So far I've managed to get our beast into some fairly hairy spots (and
out again :o) :o) :o) - places that I KNOW you would NOT be taking most
spam cans - more a testament to the easy handling of the Rebel than MY
flying ability I think !
The more I fly in "other aircraft" - the happier I am that we built a
REBEL !
Biggus
(Rick)
541R
Sent: Saturday, June 04, 2005 1:40 PM
Hello Rick,
kill
once.
Rick Harper
G'day from OZ !
:o)
are
doing :o) :o) :o)
Rick Harper
541R
short
aluminum
A Hewko
Rick Harper
G'day Wayne !
Yep ..... it takes less than a half a second to put the flaps from
FULL DOWN to FULL UP (reflexed) with either your, or my, flap handle
design ..... and I ALWAYS 3 point her onto the deck - (except in 30
Knot cross winds , where she gets 2 pointed (rear and one side) first !
:o)
Sent: Saturday, June 04, 2005 2:05 PM
Subject: Re: Flap Handle & landing
little
getting too
from
but all
nicely. I
loop if
Hello Rick,
kill
you
bite
once.
Of
Rick Harper
G'day from OZ !
here
:o)
are
doing :o) :o) :o)
Rick Harper
541R
inches
short
flight
aluminum
A Hewko
