turn buckles
Jones, Michael
turn buckles
Post by Jones, Michael » Sat Feb 18, 2012 10:32 am
hi all
i need help on the turn buckles for the cable controls
the size in my kit says stamped on it an130-8s, this would fit the cable
thimble and i seen to recall reading somewhere its for ultra lights any way
so in looking at spruce book and Murphy manual the size in manual says
an130-22s for the assembly, i look up in separate parts in spruce book and
they should be as follows
barrel an155-22s
fork end an161-22s (right or left)
eye end an170-22s (right or left)
however in spruce book there is no part listed for the barrel an155-22s, it
is blanked out, what is everyone using in their kits, what is stamped on the
actual barrel
thank
mike#007
Jones, Michael
turn buckles
HI ALL
after further research have found the correct stuff, just called spruce,
they always hep
thank
mike#007
Jones, Michael
Sent: Thursday, May 26, 2005 10:33 AM
To: Rebel-Builders EMIAL (E-mail)
Subject: turn buckles
hi all
barrel an155-22s
actual barrel
thank
mike#007
