Stabilizer Installation
Post by Mike Davis » Fri Feb 17, 2012 4:20 pm
Received: from JimsRebel@aol.com
by imo22.mx.aol.com (IMOv13.ems) id GULZa09340
for <murphy-rebel@dcsol.com>; Thu, 12 Mar 1998 20:34:02 -0500 (EST)
Message-ID: <8cf55db3.35088d0d@aol.com>
Date: Thu, 12 Mar 1998 20:34:02 EST
Mime-Version: 1.0
Subject: Stabilizer Installation
X-Mailer: AOL 3.0 for Windows 95 sub 49
HI all ... I will pass along the following correspondence I had with Murphy
regarding mounting the stabilizer. I am interested if anyone else has done
this on their aircraft.. JIm LePard JimRebel@aol.com
Subj: Re: Stabilizer installation
Date: 98-03-12 13:57:17 EST
From: murtech@murphyair.com (Murphy Aircraft Tech Department)
To: JimsRebel@aol.com (JimsRebel)
At 04:14 PM 3/11/98 EST, you wrote:
Hi Murtech .... Regarding Stabilizer Installation ,,,
Chapter 20-7 figure 7A & 7B has the front stab mounting with one AN4-5A
bolt
on each side .... I believe this was for trailering the aircraft ( hinging
the stab's to reduce the width to a road legal width ) I would like to use
two AN3-5A bolts as I will not need to hinge the stab and this would
increase
the safety and strength of the tail (also a backup if the tail strut tube
broke ). Also the nut plates shipped with the kit are F5000-3 they should
be
.. F5000-4 as in fig 7A.
Jim LePard
jimsrebel@aol.com
Hi jim
Your proposal of two bolts sounds good.
I will send you the f5000-4s that you need.
regards;
Dennis>
Murphy Aircraft Mfg. Ltd.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Received: from ts33-16.tor.istar.ca [204.191.149.175]
by mail1.toronto.istar.net with smtp (Exim 1.80 #5)
id 0yDUwG-0006Lg-00; Fri, 13 Mar 1998 08:55:56 -0500
Mime-Version: 1.0
Subject: Re: Stabilizer Installation
Message-Id: <E0yDUwG-0006Lg-00@mail1.toronto.istar.net>
Date: Fri, 13 Mar 1998 08:55:56 -0500
My only comment/observation is:
FWIW - mods. like this will likely have a large impact on the resale value
of your Rebel (negatively !!). Many buyers are very cautious, and want an
aircraft that is 'factory standard', so they can get support. Seeing
something
like extra bolts will get them wondering 'what ELSE is
different/added/missing?!!'.
....bobp
ps
Nobody has lost a tail strut, yet ! This is a bit like the earlier
debate
about "beefing up" the landing gear - "if it ain't broke, ..... ", and the
Rebel is plenty strong.
------------------------------------orig.-----------------------------------
done
bolt
hinging
use
increase
be
Jim LePard
jimsrebel@aol.com
Hi jim
regards;
Dennis>
Ph: 1-604-792-5855
Fax: 1-604-792-7006
