If you have a fast build Moose kit that has leaking wing tanks and was
from the overseas factory Darryl is sending out "fix" kits. Link to the
details on the front page of MAM site.
Scott
Moose - Overseas FB leaky tank fix from MAM
COPY OF MAM LETTER
"May 11, 2005
Dear SR2500 & SR3500 Quick Build Customers:
As most of you know there is a problem with a number of the Quick Build fuel
tanks leaking. When we were first notified of this problem we had hoped
that there would be only a few occurrences; however this has not been the
case.
It has become apparent that very few Quick Build Wings built in the
Philippines do not leak. The Philippine Builder (Wright Aircraft) had
ensured us that each tank had been pressure checked. Obviously this was not
true. Leaky tanks have not been a problem with Quick Built wings assembled
at Murphy Aircraft.
At the present time thirteen of the Quick Build aircraft from the
Philippines are flying as well as 26 aircraft build from straight kits.
We strongly suggest that all builders either pressure check or fill the
tanks with fuel and let sit for a few days before installing on the
fuselage.
Murphy Aircraft will supply to all Philippine Quick Build Wing Owners the
following materials to repair their leaking tanks:
2 QT Proseal
12 Larger Inspection Covers (Part # W1011)
550 Tank Rivets
Murphy Aircraft will also be giving each Quick Build customer affected by
the leaking tanks a $500.00 credit in the Parts Department to be used on
Murphy Aircraft Manufactured Parts.
If you have Philippine Quick Built wings and are experiencing leaking tanks
please contact the shipping department. They will forward the repair kit to
you.
Sincerely,
Darryl Murphy
President, Murphy Aircraft Mfg. Ltd."
sa@mwutah.com
Sent: Monday, May 23, 2005 6:56 PM
Subject: Moose - Overseas FB leaky tank fix from MAM
Scott
"May 11, 2005
case.
at Murphy Aircraft.
fuselage.
2 QT Proseal
550 Tank Rivets
you.
Sincerely,
Darryl Murphy
sa@mwutah.com
Scott
-------- Forwarded Message ---------
Original: DATE..... 5/23/2005 4:27 PM
Original: FROM..... KB_OLIVER@VERIZON.NET
Original: TO....... REBEL-BUILDERS
Original: SUBJECT.. RE: Moose - Overseas FB leaky tank fix from MAM
Original: FORUM.... Rebel Builders
Forwarded By....... SteveH on 5/24/2005 3:43 AM
Received: by dcsol.com (Wildcat! SMTP Router v6.1.451.4)
for rebel-builders@dcsol.com; Mon, 23 May 2005 16:26:00 -0800
Received: from vms048pub.verizon.net ([206.46.252.48])
EHLO=vms048pub.verizon.net
by dcsol.com (Wildcat! SMTP v6.1.451.4) with SMTP
id 244133125; Mon, 23 May 2005 16:25:58 -0800
Received: from kbodesktop ([64.223.231.213])
by vms048.mailsrvcs.net (Sun Java System Messaging Server 6.2 HotFix 0.04
(built Dec 24 2004)) with ESMTPA id <0IGY00BH9X6N3H76@vms048.mailsrvcs.net>
for
rebel-builders@dcsol.com; Mon, 23 May 2005 19:25:53 -0500 (CDT)
Date: Mon, 23 May 2005 20:27:13 -0400
Subject: RE: Moose - Overseas FB leaky tank fix from MAM
In-reply-to: <49308.205.174.22.27.1116888933.squirrel@205.174.22.27>
Message-id: <OOEKJIFLFBHLPIAIOOMNEEMJCCAA.kb_oliver@verizon.net>
X-Orig-MIME-version: 1.0
X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2900.2527
X-Mailer: Microsoft Outlook IMO, Build 9.0.2416 (9.0.2910.0)
X-Orig-Content-type: text/plain; charset=iso-8859-1
X-Orig-Content-transfer-encoding: 7bit
Importance: Normal
X-Priority: 3 (Normal)
X-MSMail-priority: Normal
X-Virus-Assassin: Message filtered with wsAV v3.0.0 Build 001
COPY OF MAM LETTER
"May 11, 2005
case.
at Murphy Aircraft.
fuselage.
2 QT Proseal
550 Tank Rivets
you.
Sincerely,
Darryl Murphy
sa@mwutah.com
Scott
----- End of Forwarded Message -----
for
Importance: Normal
COPY OF MAM LETTER
"May 11, 2005
case.
at Murphy Aircraft.
fuselage.
2 QT Proseal
550 Tank Rivets
you.
Sincerely,
Darryl Murphy
sa@mwutah.com
Scott
