Lexan window sealant
jtpackard
Post by jtpackard » Sat Feb 18, 2012 10:24 am
Question about window sealant.
I've been trying to find a good sealant for my Lexan side windows. I
tried some GE Silicone II, and two different Urethane sealants on test
samples. A week later, the Urethane sealants still haven't cured and
I'm not all that thrilled with the adhesion of the Silicone. Maybe I
need to use some ProSeal Polysulfide instead. What have others been
using?
Tom Packard
SR 043
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
Tim Saxton
Post by Tim Saxton » Sat Feb 18, 2012 10:24 am
Tom,
I am planning on using clear Lexel, available at Ace Hardware stores. This
is a general indoor/outdoor sealant described as being superior to silicon.
Some RV builders have used it and reported good results. Give it a test and
let us know how it works.
More info at
http://www.sashcosealants.com/home_impr ... ndex.shtml
Tim
SR060
Sent: Saturday, April 16, 2005 8:16 AM
Subject: Lexan window sealant
using?
Tom Packard
SR 043
jtpackard
Thanks Tim:
I'll pick some up today and try it out on a sample. Next week I'll post the
results.
Tom
Sent: Saturday, April 16, 2005 11:17 AM
Subject: Re: Lexan window sealant
Tom,
silicon.
More info at
Tim
SR060
using?
Tom Packard
SR 043
Al Paxhia
Post by Al Paxhia » Sat Feb 18, 2012 10:24 am
Hi Guys,
I used the white Lexel for the side windows and skylights and it works
great. We were able to paint right up to the edges of the windows and not
worry about silicon contamination of the aluminum.
Al
Sent: Saturday, April 16, 2005 9:45 AM
Thanks Tim:
results.
Tom
Tom,
This
silicon.
More info at
Tim
SR060
using?
Tom Packard
SR 043
jtpackard
Post by jtpackard » Sat Feb 18, 2012 10:27 am
Tim, Al and all:
This past week I have compared a couple of additional window sealants. The
one that Tim and Al recommended called Lexel (made by Sashco) and a new GE
Silicone II called XST (Extreme Silicone Technology). My testing was done
with sealant placed between a piece of Lexan (Polycarbonate) and epoxy
primed piece of 6061 Alum. The sealant was about 1 inch wide and approx.
.010" thick.
After 4 days the GE XST shows the most cure and is difficult to separate the
Lexan from Alum. The bond failure is between the sealant and
Lexan.(probably a good thing if you ever want to remove/replace a window).
It is also paintable and apparently water based.(instructions say clean up
with soapy water).
The Lexel is slower curing and when I separate the Lexan from the Alum., it
appears the sealant adhesion is equal to each material. I suspect the bond
will be very difficult to break when fully cured, making window replacement
more difficult without damaging surrounding structure. Lexel is also
paintable but not water based.
Conclusion: I think each will work very well. I only wonder how difficult
it will be to replace a window if Lexel sealant is used.
Regards,
Tom Packard
SR043
Sent: Saturday, April 16, 2005 2:23 PM
Hi Guys,
Al
Thanks Tim:
results.
Tom
Tom,
This
silicon.
More info at
Tim
SR060
test
Post by Bob Patterson » Sat Feb 18, 2012 10:27 am
Hi Tom !
For what it's worth, I've always used Bostick 1100 - the stuff
recommended by the windshield manufacturers. It has relatively
low adhesion and great flexibility - this is desirable, given that the
Lexan must 'float' in the frames to allow for expansion with heat.
(a windshield will expand well over 1/4" in summer ...)
Bostick 1100 comes in caulking gun tubes, is easy to work with,
inexpensive, and available in colours - white, grey, black ....
used the black for windshield, white for skylights, as it is paintable.
It's available from most building supply houses.
.......bobp
On Friday 22 April 2005 10:37 am, jtpackard@usfamily.net wrote:
Tim, Al and all:
The
new GE
done
approx.
.010" thick.
separate the
window).
clean up
with soapy water).
Alum., it
bond
replacement
difficult
Regards,
Tom Packard
SR043
Hi Guys,
works
and not
Al
Thanks Tim:
I'll post
results.
Tom
stores.
silicon.
a test
windows.
on
test
cured and
Maybe I
been
steve whitenect
Post by steve whitenect » Sat Feb 18, 2012 10:27 am
Am in the process of puting mine in this weekend. Am using RTV 733 on both
sides. Have the two sides done and will be doing the rest tomorrow. Taping
around the retainer on the window and cleaning as I go. So far looks good
and I have enough on the inside to prevent chafing. Will use the 733
between the glass and all retainer strips and a polyurethane under the
fiberglass lower strip against the aluminum.
Steve W.
Rebel 637
