O-235-C1 Available
O-235-C1 Available
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:20 am
There was a few guys looking for a cheap way to get their machines in the
air and be easily upgradable to higher HP later on!
I have a guy looking to sell his O-235-C1 x 108 HP (115HP for take off).
Fresh bottom end bearings, tappets and cam. All work was done by Mark Elste
at Airparts in Winnipeg. Basically the bottom end is now zero timed, top is
still 600SMOH but all cylinders are still to spec. Nice thing about this is
you wouldn't have to worry about breaking in the rings on your first
flights! NO starter or Carb included. Asking $7000cdn ....with some room for
negotiation. If anyone is interested send me an email at
oifa@irishfield.on.ca and I'll hook you up with the guy. Engine is still at
the engine shop, so if you wanted new rings this could be done for extra if
you wanted to bother.
Wayne O'Shea
0235-C1 engine 600 smoh and 2600 ttsnew
Just done new main bearings, replaced all tappetes and cam, all steel
cylinders std and one is 10 over, all work done at airparts network in
Manitoba
Come with a set of yellow tagged bendix mags new in 1965 new never used sold
from leavens still have original tags
