Scott,
Did you do anything to beef up the main gear?
Oh, why I am at it, I still think the main gear attach set up on the
SR/Moose is crap too, and that "anomaly" will arise (or collapse:) )
again in the future.
Moose Main Gear?
Moose Main Gear?
Short answer - yes. Long answer to follow.Scott,
As soon as I posted that I regretted. The "collapse" part was supposed to be
tongue in check; I don't think anyone is going to have a failure due to the
design under normal circumstances.
We have been over this before but it was awhile ago. The Moose gear could
probably withstand a drop straight down off the top of a building <grin> but
don't screw up and land with a side load too often. Due to the gear leg
being essentially straight all side loads are transferred straight up and
across and are trying to shear the main gear attach bolt off. The bolt is
in single shear. It would be better (and cost more to manufacture) if the
gear leg came up and then bent over horizontal and then you could have the
inner bracket similar to the P. Ponk modification for Cessna's
(http://www.pponk.com/ look under landing gear and then beef up kit and
there is an exploded view).
Murphy made up Jim Moore a complete new set of gear with all 4130 steel
brackets (inner and outer), gear legs bent over a la Cessna and two solid
1/8" aluminum plates across the front and back of the gear box. Last I
emailed Jim he still wasn't back in the air so no report. It weighs a lot
more than the standard setup. He said both his main gear bolt holes were
worn to an oval shape in the inner 6061 brackets. So they have already made
a better set of gear but don't think there is anything wrong with the
current set so are leaving it as is (as far as I know, which isn't much). I
think they will regret that once more time gets put on the fleet but I hope
I am wrong.
The twisting drag loads are another issue. They said it was mostly due to
the large Alaska wheel mod and they put out a bulletin to add the drag brace
behind each outer fitting (I saw that yours has those installed Ted). That
was supposed to fix that but I am not sure how many hours they actually put
on the demonstrator after the fix with the big wheels.
I added longer/bigger drag braces behind each outer gear bracket. I changed
the FUS 310 (which is the lower portion of the outer bracket) to steel and
upped the size of the outer attach bolts. I made a steel U shaped bracket
that goes over the top of the inner gear bracket and gear leg. The gear leg
slips up into this U so the bolt now goes down through the steel, through
the gear leg, then the MAM aluminum bracket and then through the bottom of
my steel U. The U shaped bracket is held in place by side flanges that pick
up the same bolt that hold the main bracket in place. Then there is steel
square tube that runs across the gear box connecting the two gear legs
together to give more side load protection.
Not sure if this will really do anything but I feel better. Once I get some
time on it I will see.
Sorry that was so long.
Scott
Moose 174
Waltman
Sent: Friday, April 01, 2005 9:22 AM
Subject: Moose Main Gear?
Scott,
Moose Main Gear?
Could you post some pictures of the mod you did to the main gear? ? ? ?
Steve H
Moose 213
-> > Scott,
-> > Did you do anything to beef up the main gear?
-> > Ted
-> Short answer - yes. Long answer to follow.
-> As soon as I posted that I regretted. The "collapse" part was supposed to be
-> tongue in check; I don't think anyone is going to have a failure due to the
-> design under normal circumstances.
-> We have been over this before but it was awhile ago. The Moose gear could
-> probably withstand a drop straight down off the top of a building <grin> but
-> don't screw up and land with a side load too often. Due to the gear leg
-> being essentially straight all side loads are transferred straight up and
-> across and are trying to shear the main gear attach bolt off. The bolt is
-> in single shear. It would be better (and cost more to manufacture) if the
-> gear leg came up and then bent over horizontal and then you could have the
-> inner bracket similar to the P. Ponk modification for Cessna's
-> (http://www.pponk.com/ look under landing gear and then beef up kit and
-> there is an exploded view).
-> Murphy made up Jim Moore a complete new set of gear with all 4130 steel
-> brackets (inner and outer), gear legs bent over a la Cessna and two solid
-> 1/8" aluminum plates across the front and back of the gear box. Last I
-> emailed Jim he still wasn't back in the air so no report. It weighs a lot
-> more than the standard setup. He said both his main gear bolt holes were
-> worn to an oval shape in the inner 6061 brackets. So they have already made
-> a better set of gear but don't think there is anything wrong with the
-> current set so are leaving it as is (as far as I know, which isn't much). I
-> think they will regret that once more time gets put on the fleet but I hope
-> I am wrong.
-> The twisting drag loads are another issue. They said it was mostly due to
-> the large Alaska wheel mod and they put out a bulletin to add the drag brace
-> behind each outer fitting (I saw that yours has those installed Ted). That
-> was supposed to fix that but I am not sure how many hours they actually put
-> on the demonstrator after the fix with the big wheels.
-> I added longer/bigger drag braces behind each outer gear bracket. I changed
-> the FUS 310 (which is the lower portion of the outer bracket) to steel and
-> upped the size of the outer attach bolts. I made a steel U shaped bracket
-> that goes over the top of the inner gear bracket and gear leg. The gear leg
-> slips up into this U so the bolt now goes down through the steel, through
-> the gear leg, then the MAM aluminum bracket and then through the bottom of
-> my steel U. The U shaped bracket is held in place by side flanges that pick
-> up the same bolt that hold the main bracket in place. Then there is steel
-> square tube that runs across the gear box connecting the two gear legs
-> together to give more side load protection.
-> Not sure if this will really do anything but I feel better. Once I get some
-> time on it I will see.
-> Sorry that was so long.
-> Scott
-> Moose 174
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ted
-> > Waltman
-> > Sent: Friday, April 01, 2005 9:22 AM
-> > To: rebel-builders@dcsol.com
-> > Subject: Moose Main Gear?
-> > Scott,
-> > Ted
-> > Oh, why I am at it, I still think the main gear attach set up on the
-> > SR/Moose is crap too, and that "anomaly" will arise (or collapse:) )
-> > again in the future.
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
Steve H
Moose 213
-> > Scott,
-> > Ted
-> I am wrong.
-> Scott
-> Moose 174
-> > Waltman
-> > Scott,
-> > Ted
Moose Main Gear?
Done.
The real fix (if it really needs fixing??) would be to have what Jim has. I
couldn't find the pictures he sent, I will post when I do.
Scott
Moose 174
Scott
Moose 174
steveh@dcsol.com
Sent: Friday, April 01, 2005 11:34 AM
Subject: RE: Moose Main Gear?
Steve H
Moose 213
-> > Scott,
-> > Ted
to be
could
<grin> but
leg
is
solid
lot
were
made
much). I
hope
-> I am wrong.
due to
brace
That
put
changed
bracket
gear leg
through
pick
steel
some
-> Scott
-> Moose 174
-> > Waltman
-> > Scott,
-> > Ted
Moose Main Gear?
Just uploaded three pictures of the one of kind Moose gear, which in my
opinion is how they should all be made.
MAM are you lurking??
Scott
Moose 174
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Scott
Aldrich
Sent: Friday, April 01, 2005 12:11 PM
Done.
Scott
Moose 174
Scott
Moose 174
Aldrich
Done.
Scott
Moose 174
steveh@dcsol.com
Steve H
Moose 213
-> > Scott,
-> > Ted
to be
could
<grin> but
leg
is
solid
lot
were
made
much). I
hope
-> I am wrong.
due to
brace
That
put
changed
bracket
gear leg
through
pick
steel
some
-> Scott
-> Moose 174
-> > Waltman
-> > Scott,
-> > Ted
Moose Main Gear?
That's a dumb question Scott!! LOL
Sent: Friday, April 01, 2005 2:32 PM
ScottMAM are you lurking??
Scott
Moose 174
IAldrich
Done.
supposedcouldn't find the pictures he sent, I will post when I do.
Scott
Moose 174
steveh@dcsol.com
Steve H
Moose 213
-> > Scott,
-> > Ted
toto be
boltthe
could
<grin> but
leg
ifis
havethe
andthe
steel-> there is an exploded view).
I-> brackets (inner and outer), gear legs bent over a la Cessna and two
solid
already-> emailed Jim he still wasn't back in the air so no report. It weighs a
lot
were
Imade
much). I
draghope
-> I am wrong.
due to
actuallybrace
That
steelput
changed
bottomand
bracket
gear leg
through
thatof
legspick
steel
get-> together to give more side load protection.
Ofsome
-> Scott
-> Moose 174
theTed
-> > Waltman
-> > Scott,
-> > Ted
collapse:) )-> > SR/Moose is crap too, and that "anomaly" will arise (or
