EL-303
bscheube
EL-303
Post by bscheube » Sat Feb 18, 2012 10:20 am
Hi all,
Quick question about the ribs (EL-303 all 29 for tail sub-kit) the ribs I have
seem to have a pretty good bend to them. I have uploaded a picture to the
files Moose misc. I put the rib vertical and lay a straight edge next to it in
the center of the rib there is about a 1/4" gap? Is the normal???? It is that
way on all of them. The bend can be straightened while laying flat with a
little downward pressure (springs right back when released). following the
directions for drawing the line down the center of the flange it seems like it
will be a pain to keep it straight while drilling and riveting. There is no
visible deformaties (bends or crinkles).
Thanks for the help.
Bob Scheuber
rognal
EL-303
Post by rognal » Sat Feb 18, 2012 10:20 am
Bob,
I'm building the Rebel, not a Moose, but from your description it sounds like
you need to straighten the ribs using fluting pliers. If your not familiar
with the procedure, try this link for desc & photos:
http://www2.mstewart.net:8080/michael/r ... luting.htm
Or try a Google search for "fluting" ribs and see what comes up. Just make
sure you know where the rivet holes will be and flute between them. Also go
slow and easy.
Hope this helps.
Roger Hoffman #687R
Eugene, OR USA!
bscheube
EL-303
Roger,
I looked at the link and that is exactly what I will need to do. Now I have to
add to the tool collection and find some Fluting pliers.
Thanks. Bob
On 3/20/2005 5:19 PM, ROGNAL wrote to BOB SCHEUBER:
-> Bob,
-> I'm building the Rebel, not a Moose, but from your description it sounds
like
-> you need to straighten the ribs using fluting pliers. If your not familiar
-> with the procedure, try this link for desc & photos:
-> http://www2.mstewart.net:8080/michael/r ... luting.htm
-> Or try a Google search for "fluting" ribs and see what comes up. Just make
-> sure you know where the rivet holes will be and flute between them. Also go
-> slow and easy.
-> Hope this helps.
-> Roger Hoffman #687R
-> Eugene, OR USA!
EL-303
Post by Mike Davis » Sat Feb 18, 2012 10:20 am
Hi Bob, I know a lot of people use fluting pliers for this, but I did all
mine with a shrinker... that way I don't have the waves in the flange and
don't have to worry about where the rivets line up. I just did a couple of
soft taps on the shrinker handle every inch or so the entire length and they
came out nice and straight with the flanges still smooth.
195SR
Sent: Sunday, March 20, 2005 4:33 PM
Subject: EL-303
Hi all,
have
it in
that
like it
no
Bob Scheuber
bscheube
EL-303
Mike,
thanks for the reply, where would I find a shrinker? I did a search on spruce
and didn't come up with anything....
Thanks. Bob Scheuber 191SR
-> Hi Bob, I know a lot of people use fluting pliers for this, but I did all
-> mine with a shrinker... that way I don't have the waves in the flange and
-> don't have to worry about where the rivets line up. I just did a couple of
-> soft taps on the shrinker handle every inch or so the entire length and
they
-> came out nice and straight with the flanges still smooth.
-> Mike
-> 195SR
-> From: <bscheube@dcsol.com>
-> Sent: Sunday, March 20, 2005 4:33 PM
-> Subject: EL-303
-> > Hi all,
-> > Quick question about the ribs (EL-303 all 29 for tail sub-kit) the ribs I
-> > have
-> > seem to have a pretty good bend to them. I have uploaded a picture to the
-> > files Moose misc. I put the rib vertical and lay a straight edge next to
-> > it in
-> > the center of the rib there is about a 1/4" gap? Is the normal???? It is
-> > that
-> > way on all of them. The bend can be straightened while laying flat with a
-> > little downward pressure (springs right back when released). following the
-> > directions for drawing the line down the center of the flange it seems
-> > like it
-> > will be a pain to keep it straight while drilling and riveting. There is
-> > no
-> > visible deformaties (bends or crinkles).
-> > Thanks for the help.
-> > Bob Scheuber
Scott Aldrich
EL-303
Post by Scott Aldrich » Sat Feb 18, 2012 10:20 am
Bob, these guys http://www.aircraft-tool.com/shop/search_result.aspx have
both fluting pliers and the shrinker. If you do a search for shrinker -
stretcher you will get a bunch of hits. Definitely cheaper to go with the
pliers but there have been a few times I wish I had a shrinker and stretcher
for custom parts.
Scott
Moose 174
bscheube@dcsol.com
Sent: Sunday, March 20, 2005 9:24 PM
Subject: Re: EL-303
Mike,
spruce
all
couple of
they
-> Mike
-> 195SR
-> Subject: EL-303
-> > Hi all,
ribs I
-> > have
-> > it in
is
-> > that
with a
following the
seems
-> > like it
is
-> > no
-> > Bob Scheuber
Scott Aldrich
EL-303
Sorry, bum link last time.
http://www.aircraft-tool.com/shop/detai ... rnPage=/sh
op/search_result.aspx?PageNo=1
Scott
Scott Aldrich
Sent: Sunday, March 20, 2005 9:37 PM
Subject: RE: EL-303
stretcher
for custom parts.
Scott
Moose 174
bscheube@dcsol.com
Subject: Re: EL-303
Mike,
spruce
all
couple of
they
-> Mike
-> 195SR
-> Subject: EL-303
-> > Hi all,
ribs I
-> > have
next
-> > it in
It
is
-> > that
with a
following the
seems
-> > like it
There
is
-> > no
-> > Bob Scheuber
bscheube
EL-303
thanks Scott.
Got the link to work. order complete. thanks to all who answered.
Bob 191SR
On 3/20/2005 7:36 PM, SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> Bob, these guys http://www.aircraft-tool.com/shop/search_result.aspx have
-> both fluting pliers and the shrinker. If you do a search for shrinker -
-> stretcher you will get a bunch of hits. Definitely cheaper to go with the
-> pliers but there have been a few times I wish I had a shrinker and stretcher
-> for custom parts.
-> Scott
-> Moose 174
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of
-> > bscheube@dcsol.com
-> > Sent: Sunday, March 20, 2005 9:24 PM
-> > To: rebel-builders@dcsol.com
-> > Subject: Re: EL-303
-> > Mike,
-> > thanks for the reply, where would I find a shrinker? I did a search on
-> > spruce
-> > and didn't come up with anything....
-> > Thanks. Bob Scheuber 191SR
-> > -> Hi Bob, I know a lot of people use fluting pliers for this, but I did
-> > all
-> > -> mine with a shrinker... that way I don't have the waves in the flange
-> > and
-> > -> don't have to worry about where the rivets line up. I just did a
-> > couple of
-> > -> soft taps on the shrinker handle every inch or so the entire length and
-> > they
-> > -> came out nice and straight with the flanges still smooth.
-> > -> Mike
-> > -> 195SR
-> > -> ----- Original Message -----
-> > -> From: <bscheube@dcsol.com>
-> > -> To: <rebel-builders@dcsol.com>
-> > -> Sent: Sunday, March 20, 2005 4:33 PM
-> > -> Subject: EL-303
-> > -> > Hi all,
-> > -> > Quick question about the ribs (EL-303 all 29 for tail sub-kit) the
-> > ribs I
-> > -> > have
-> > -> > seem to have a pretty good bend to them. I have uploaded a picture to
-> > the
-> > -> > files Moose misc. I put the rib vertical and lay a straight edge next
-> > to
-> > -> > it in
-> > -> > the center of the rib there is about a 1/4" gap? Is the normal???? It
-> > is
-> > -> > that
-> > -> > way on all of them. The bend can be straightened while laying flat
-> > with a
-> > -> > little downward pressure (springs right back when released).
-> > following the
-> > -> > directions for drawing the line down the center of the flange it
-> > seems
-> > -> > like it
-> > -> > will be a pain to keep it straight while drilling and riveting. There
-> > is
-> > -> > no
-> > -> > visible deformaties (bends or crinkles).
-> > -> > Thanks for the help.
-> > -> > Bob Scheuber
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
EL-303
Glad you found one Bob... I just bought the deluxe tool kit from Murphy when
I bought my kit... came with both fluting pliers, and the
shrinker/stretcher.
195SR
Sent: Sunday, March 20, 2005 7:23 PM
Subject: Re: EL-303
Mike,
spruce
all
couple of
they
-> Mike
-> 195SR
-> Subject: EL-303
-> > Hi all,
ribs I
-> > have
-> > it in
is
-> > that
with a
following the
seems
-> > like it
is
-> > no
-> > Bob Scheuber
rognal
EL-303
Bob,
Glad I could help.
Roger
