by m2.interserv.com (8.8.5/8.8.5) with ESMTP id GAA08248
for <murphy-rebel@dcsol.com>; Sat, 28 Feb 1998 06:19:13 -0800 (PST)
Message-ID: <34F81CFB.AD6E86A5@interserv.com>
Date: Sat, 28 Feb 1998 06:19:39 -0800
X-Mailer: Mozilla 4.04 [en] (Win95; U)
MIME-Version: 1.0
To: "(Murphy Rebel)" <murphy-rebel@dcsol.com>
Subject: Re: Cross over exhaust instructions
References: <2.2.16.19980225080345.37cfd836@pop.uniserve.com>
FYI. Note that Murphy says they have no instructions.
Murphy Aircraft Tech Department wrote:
areHi Walter,
Unfortunately we do not have any instructions for this installaiton as we
only dealw iuth firewall aft. From what I understand the muffler pipes
slidelabelled to fit to the correct cylinders. Once mounted the two halves
5/16"together. Robin suggested using a torque that is the same as for the
cowlstandard nut. As far as the brakcets, you will have to make some to come
off the engine mount and attach to the tail pipe to prevent movement,
however there is no one set method of bracketing. We cut the tail pipe
flsuh with the end of the cowl and found that we didn't need any rear
bracketing. As far as the muffler, the mufflers cannot fit inside the
foundand therefore have to be mounted aft of the cowl externally. We have
that the muffle doesn't quiet the engine much. I hope this helps,
Bijan
At 07:22 PM 2/23/98 -0800, you wrote:Murphy Aircraft Mfg. Ltd.I bought your cross over exhaust system a couple of years
ago, and am now ready to mount it on the engine for the
final time. I understand from the email users group that you
now have instructions. I did not receive any when I made my
purchase. Could you send me a set? In particular, I would
like to know how to brace the tail ends of the pipes, what
torque for the manifold nuts, etc. Is it possible to fit in
a muffler? Thanks.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
