throttle spacing
Jones, Michael
throttle spacing
Post by Jones, Michael » Sat Feb 18, 2012 10:16 am
hi all
to quiet out there today, so i ask first question
what is spacing betweem throttle, carb heat, mixture, typical numbers
mike#007
rognal
Throttle Spacing
Post by rognal » Sat Feb 18, 2012 10:16 am
Mike,
I asked this question of the list awhile back. Here's the thread. Hope it
helps. I ended up using 2.5" spacing on my panel.
12/16/03
All,
Can anyone advise me what the accepted distance is between throttle and
mixture controls, center to center? I don't have access to an aircraft at the
moment to take a measurement so thought I would ask. I did not want to get
them so close together that operating one would interfere with the other, yet
I don't want to get them to far apart and waste panel space.
Thanks for the help,
Roger Hoffman #687R
Eugene, OR USA!
Hi Roger,
Just drilled the holes for the throttle and prop in out Moose panel a few
days ago. (M-14, no mixture) I recall we placed them on 2.5" centers. I will
verify tomorrow at the shop and re-email if different. We did a little mock
up and found the distance we thought ... not too close ... not too far.
Later,
Don B
Roger,
I tried a 2.75" spacing on a piece of wood and it felt awkward. Then I
measured a Cessna 172 and used that dimension. It is 2.5". The 2.5" seems to
be
perfect.
Good luck,
Rick D.
END
sa
throttle spacing
Post by sa » Sat Feb 18, 2012 10:16 am
I used 3 inch centers between the throttle and my prop controls, seems
comfortable.
Scott
"Jones, Michael" <MJones@hatch.ca> wrote in message
news:05Mar7.120346est.332689@gateway.hatch.ca...
hi all
mike#007
