rear float brackets
Gilles St-Pierre
rear float brackets
Post by Gilles St-Pierre » Sat Feb 18, 2012 10:16 am
Bob
I checked your site and noticed the rear float bracket was brought forward 1
station
was wondering if it should be done when using Clamar 2200 amphibious floats
Beautiful pictures,i did pick some hints......!
thanks
gilles e717
Subject: Re: wing access cover
Date: Mon, 07 Mar 2005 15:56:24 -0500
Hello Mike
Wing is close and the doubler is already rivet from the outside. Cover is
done with "rivnut" system to hold them. Look is not too bad, but not
"clean" as inside doubler. Too late for the right wing. Question will be
left one cleaner or symitric to the right one..... How fit the skin at the
edge of the doubler in the spar area? Coupled of months ago, there was a
good aticle too in the Kitplane magasine on how make access hole. Thanks
for all
Jean
Rebel 747R
Sent: Monday, March 07, 2005 1:36 PM
Subject: RE: wing access cover
jean
if wing is open doublers can go inside, looks better from outside this
way,
cover plate covers a lot of rivets
if wing closed doublers might have to go on outside, might
i have document from Murphy that shows how to do circular doublers with
closed wing
will get document scan and post if you want
mike#007
Jean Poirier
Sent: Monday, March 07, 2005 1:26 PM
To: rebel builder
Subject: wing access cover
Hello!
In the files, I have saw pictures of wing access cover with the doubler
inside of the wing. That picture have put trouble in my life!
Nowhere
in
the manual they say to put it inside and with the way hole ares dones,
have always imagine the doubler was suppose to be outside! Is it just
modification (nice one) that someone have done or it should be done like
that?
Jean
Rebel 747R
Bob Andrews
rear float brackets
Post by Bob Andrews » Sat Feb 18, 2012 10:16 am
gilles ... thanks on the e612 site. Regarding the Clamar 2200A's ... I have
to admit that I know zippidy do da point dump about them. As to what the
aft vertical strut would look like with Clamar's attached to the MAM
fitting, it depends on the distance between their aft spreader bar and the
step. The step defines where the floats are mounted fore and aft w/r/t the
wing cord/fuselage, and since that's where the bottom of the aft vertical
strut attaches to the float, that will define the angle to the MAM fitting.
When the green/white Elite was flying with MFC 2200A's, and the aft struts
were connected to MAM's aft fittings, they sloped aft almost parallel with
the front vertical struts. When they were moved to the door post, they were
near vertical. According to Keith, and I agree, the aft strut should be as
vertical as possible when the floats are level ... and moving them forward
one station (to the aft door post) does the trick. Now that's not to say
that connecting them to the MAM fitting is bad or wrong anything like that
... the Green/White Elite flew with them that way ... as well as with them
attached one station fwd (at the base of the aft door post) later on.
Since I'm not sure if I can attach pictures to the e-list emails (Mike?) ...
here's a link to the grn/wht Elite on MFC 2200A's with the aft struts
attached to the MAM fittings www.aacnet.com/elite/gwelite.jpg ... and
another picture that I tweaked on my computer to move them up one station
www.aacnet.com/elite/gwelite2.jpg ... which is where mine will be attached.
Even though I'm overly biased toward MFC, I am sorry I couldn't be more help
with the Clamar's.
Bob e612
Gilles St-Pierre
Sent: Monday, March 07, 2005 3:20 PM
Subject: rear float brackets
Bob
station
thanks
gilles e717
Hello Mike
for all
Jean
Rebel 747R
jean
way,
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
Nowhere
in
that?
Jean
Rebel 747R
rear float brackets
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:16 am
I'll be in CLAMAR's factory on Saturday the 19th Gilles. If you want some
measurements just ask (I can take all I want without Clair getting nervous!)
Sent: Monday, March 07, 2005 6:28 PM
Subject: RE: rear float brackets
have
fitting.
were
as
attached.
help
with the Clamar's.
Bob e612
Gilles St-Pierre
Bob
1
station
floats
thanks
gilles e717
Hello Mike
is
be
for all
Jean
Rebel 747R
jean
way,
with
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
doubler
Nowhere
in
just
like
that?
Jean
Rebel 747R
Gilles St-Pierre
rear float brackets
Bob
i think you have provided the right infos. At least i know what to look for
thanks again
gilles e717
Alan Hepburn
rear float brackets
Post by Alan Hepburn » Sat Feb 18, 2012 10:16 am
Gilles:
I think I have a picture of a Rebel on Clamar floats. The rear strut is
raked well forward, just like on the Montana 2200s, but nothing was done
about it, which I don't think is very good. If your fuselage is not
finished, then it would be a much better job to have the rear attach point
at the rear of the door sill as Bob is doing (on the Elite at least). If
you have finished the fuselage with the standard MAM attach points, I have
an alternate approach to relieve the fore-aft stress from the attach point,
which we can discuss.
Al
From: "Gilles St-Pierre" <ranchlaseigneurie@hotmail.com>
Sent: Monday, March 07, 2005 5:20 PM
Bob
1
station
floats
thanks
gilles e717
Hello Mike
is
be
for all
Jean
Rebel 747R
jean
way,
with
closed wing
mike#007
Jean Poirier
To: rebel builder
Hello!
doubler
Nowhere
in
just
like
that?
Jean
Rebel 747R
Gilles St-Pierre
rear float brackets
thanks for the offer.Certainly appreciated
thanks
gilles e717
Subject: Re: rear float brackets
Date: Mon, 7 Mar 2005 19:06:37 -0500
nervous!)
have
vertical
fitting.
struts
with
were
as
forward
say
that
them
station
attached.
help
with the Clamar's.
Bob e612
Gilles St-Pierre
Bob
forward
1
station
floats
thanks
gilles e717
Hello Mike
is
will
be
was
for all
Jean
Rebel 747R
this
with
doubler
Nowhere
dones,
just
like
recipient
disseminate,
Gilles St-Pierre
rear float brackets
Al
the corner wrap has nt been instaled yet. so is quite easy to stick that in
between and we have a small machine shop to faconnate that part as
descdibed, but would still appreciate your comments on the other way to do
it
thank a lot
gilles e717
Date: Mon, 7 Mar 2005 21:20:14 -0500
Gilles:
Al
Bob
forward
1
station
floats
thanks
gilles e717
Hello Mike
is
will
be
was
for all
Jean
Rebel 747R
this
with
doubler
Nowhere
dones,
just
like
recipient
disseminate,
rear float brackets
Probably BILMAR floats Al, not CLAMAR's. I know of at least one Rebel down
your way with a set of Bilmars on it that doesn't fly right. CLAMAR's are
similar but significantly lighter, but IMHO still too heavy for the Rebel or
Elite or I'd be installing them myself.... considering I work hand in hand
with Clair Sceli already. Pretty sure the deck pickup points are pretty
similar on both mfg's floats though so the mounting strut picture would show
the "tale" without me needing to get measurements for Gilles.
Sent: Monday, March 07, 2005 9:20 PM
Gilles:
have
point,
Al
Bob
forward
1
station
floats
thanks
gilles e717
Hello Mike
is
will
be
was
for all
Jean
Rebel 747R
this
with
doubler
Nowhere
dones,
just
like
recipient
disseminate,
Bob Andrews
rear float brackets
Gilles,
At the shop, there's a side view picture (at the Oshkosh seaplane base) of
the green/white Elite with the aft struts mounted fwd one station ...
provided I remember to do it, will scan it and post in the Elite mods
section tomorrow.
Bob e612
Gilles St-Pierre
Sent: Monday, March 07, 2005 7:30 PM
Al
it
thank a lot
gilles e717
Gilles:
Al
Bob
forward
1
station
floats
thanks
gilles e717
Hello Mike
is
will
be
was
for all
Jean
Rebel 747R
this
with
doubler
Nowhere
dones,
just
like
recipient
disseminate,
Alan Hepburn
rear float brackets
Wayne:
It was Eric Draper's Rebel. I've posted the pic on Rebel/Float
Installations. The rear spreader is about the same location as on the
Montana 2200s.
Al
Sent: Monday, March 07, 2005 9:31 PM
or
show
Gilles:
point
If
have
point,
Al
Bob
forward
1
station
floats
thanks
gilles e717
Cover
is
will
be
at
was
this
with
Of
doubler
dones,
just
done
like
recipient
disseminate,
rear float brackets
Post by Bob Patterson » Sat Feb 18, 2012 10:16 am
Hi Al !
From the photo, that looks like Ron Barber's old Rebel.
The step appears to be over a foot or more too far forward -
that would account for the angle of the rear support ....
and also the poor performance !! ;-) :-)
Guess they had <some> reason for the positioning.
On Tuesday 08 March 2005 12:05 am, Alan Hepburn wrote:
Wayne:
Montana 2200s.
Al
or
show
Gilles:
point
If
have
point,
Al
forward
1 floats
Cover
is
will
be
at
was
this
with
Of
doubler
dones,
just
done
like ----------------------------------------------------------------------
recipient
disseminate,
Gilles St-Pierre
rear float brackets
thanks to all those generous souls who gave me infos on the brackets
will fabricate them tomorrow
thanks again
gilles
e717
rear float brackets
Wasn't Eric's I was thinking of....but his are Bilmars as well. He called me
more than once a week for quite some time using our money (NAV Canada on the
call display!). There was someone else in the Ottawa area that called me
wanting information on where the step should be etc for his Bilmar
Amphibs...as his wouldn't hold the nose wheels up on landing/take off
(wouldn't even rotate on take off and flew off flat). I offered my advise
and he disagreed with me....wouldn't listen to my reasoning in regards to
where the main tire postion vs C of G vs weight of the forward float
section should be. Told him if he knew the answer already then why did he
waste my time to ask and he hung up.
Sent: Tuesday, March 08, 2005 12:05 AM
Wayne:
Montana 2200s.
Al
down
are
Rebel
or
hand
show
Gilles:
is
done
point
If
have
point,
Al
forward
1 floats
Cover
is
not
will
be
skin
at
there
was
outside
this
doublers
with
Behalf
Of
doubler
dones,
it
just
done
like
recipient
disseminate,
rear float brackets
Yes Bob! Ron's old airplane. I agree..step is too far forward by about 9
inches or so comparing pictures of side to side on what I know works.
Problem may be weight (probably the + side of 380lbs for the Bilmars - which
leaves one 200 lb pilot and 4 gallons of fuel to be legal and actually
wouldn't pass TC's useful load calculation) to work out an acceptible C of
G..but I'd think further back would improve the C of G if anything. The rear
strut would still be slanted back though so moving the rear fus attach
forward as Bob (Keith) are doing makes a lot of sense. Both struts leaning
the same way just begs for collapse in a hard landing. Glad Howard's rear
strut was straight TFSure.
Mark C-FPSR Serial No 077R
Common Name Murphy Model REBEL
File Location Toronto Basis for Eligibility for Registration Amateur
Built - CAR Standard 549
Type of Registration Private
Category Aeroplane Weight (Kgs) 748
Manufacturer RON C. BARBER
Year of Manufacture 1995
Country of Manufacture CANADA
Owner Registration
Owner Registered Since 2001-08-02 Last Certificate of Registration
Issued 2001-08-02
Engine Piston Number of Engines 1
Owner Information
Name ( 1 of 1 ) 629995 Ontario Inc. Mail Recipient Yes
Address P.O. Box 98
City Braeside Province Ontario
Postal Code K0A 1G0 Region Ontario
Sent: Tuesday, March 08, 2005 9:04 PM
Hi Al !
Wayne:
Montana 2200s.
Al
down
are
Rebel
or
hand
pretty
would
show
strut is
done
point
least).
If
have point, forward
amphibious
Cover
not
Question
will
skin
at
there
was Thanks
outside
this
doublers
Behalf
Of
life!
ares
dones,
Is it
done
be
recipient disseminate,
Bob Andrews
rear float brackets
... it looks like that particular float installation has 9 to 10 degrees of
throat angle ... which also could produce less then optimal performance ...
would think 3-5 should do it leaving the rest for rotation once on-the-step
speed gets up there. What throat angle are you setting your floats at on
the Rebels?
Bob e612
Sent: Tuesday, March 08, 2005 8:35 PM
Owner Registration
Issued 2001-08-02
Owner Information
Address P.O. Box 98
Hi Al !
Wayne:
Montana 2200s.
Al
down
are
Rebel
or
hand
pretty
would
show
strut is
done
point
least).
If
have point, forward
amphibious
Cover
not
Question
will
skin
at
there
was Thanks
outside
this
doublers
Behalf
Of
life!
ares
dones,
Is it
done
be
