Folks,
To check my oil, I have to undo 19 camlocs and open up the side of my
cowl. Of course, I only do this about every three flight hours or so,
hence it isn't that big of a deal. I'm thinking of making a "small"
access door in the top of the cowl to allow me to just check the oil.
Pros: - Easily check oil as often as I like
- Reduces repeated wear on the camlocs, which, of course,
eventually start to come loose and wear through the fiberglass
Cons: Aren't opening up the cowl to give the engine & related components
a brief visual
Suggestions? What are other folks doing?
"Check Oil" door in Moose Cowl ?
Hi Ted !
If things are pretty stable under the cowl, go ahead and add
a push-to pop-open oil door - checking more often is good !
One consideration though - will it be in a suitable position,
and large enough, to allow you to ADD oil if needed ??!!!
If not, not much benefit !
I like the idea of looking things over before every flight -
just in case a birds nest has appeared, or something is loose,
but not yet broken .... This is where piano hinge fasteners
really shine - pull one wire, and open it up ! (You might need
a few camlocks at the top rear for the Moose, though !)
........bobp
........bobp
Folks,
a brief visual
Ted, I made a small oil access door on the top. I also added two small
inspection doors on the sides since I don't have the quick access camlocs
(yet, that will be a do over later once I am flying).
Scott
Waltman
Sent: Tuesday, February 15, 2005 11:51 AM
To: Murphy List
Subject: "Check Oil" door in Moose Cowl ?
Folks,
a brief visual
Scott
Waltman
To: Murphy List
Folks,
a brief visual
Good point, Bob, regarding being able to easily add oil through the same
door. Glad someone is awake and thinking today.
Not sure how to get my 2.5 gallon jugs close enough to the fill neck
<grin>...
Sent: Tuesday, February 15, 2005 12:17 PM
Subject: Re: "Check Oil" door in Moose Cowl ?
Hi Ted !
One consideration though - will it be in a suitable position, and large
enough, to allow you to ADD oil if needed ??!!! If not, not much benefit
I like the idea of looking things over before every flight - just in
really shine - pull one wire, and open it up ! (You might need a few
........bobp
<grin>...
Hi Ted !
........bobp
Folks,
components a brief visual
