Hinges
mbetti
Hinges
Post by mbetti » Sat Feb 18, 2012 10:09 am
Hi all,
I'm looking at mating the elevator to the stab and notice the hinges don't line up well. What happens is the holes in each hinge half don't line up very well with its mate and when putting a bolt through the hole it goes sideways. I'll never get the bolts in like this. If I drill it out to make it square I will end up with an oval shaped hole. What have other done here? How about drilling out to the next size.......with a free hand drill? Depending on the hours I fly this thing or how quick the bolt holes wear out I may bush it at that time.
Mike Betti
771E
Reed Britt Civ OO-ALC/MAD
Hinges
Post by Reed Britt Civ OO-ALC/MAD » Sat Feb 18, 2012 10:09 am
Mike - You might try putting bushings in - There is some history here on the
DCSOL about it - Mine came out nice - Britt - SR194
mbetti@up.net
Sent: Wednesday, February 09, 2005 6:56 AM
Subject: Hinges
Hi all,
Mike Betti
771E
