Mike, we mounted ours on a rectangular plate that had a slight curve to
match the elevator surface. The servo mounted to the plate and then the
plate was attached via nutplates to the elevator. This was done for
maintenance ease and no sealant used. Plan now how you will run the
electric feed and think about how to replace that wiring if it failed.
We ran a small aluminum tube as a wire way in the elevator. Suggest
"sleeving" the all thread that connects the servo and trim tab with
aluminum tubing for appearance and rigidity.
trim servo mounting
trim servo mounting
On that subject, where abouts does the wire exit the elevator to go to the fuselage? or stab?
trim servo mounting
We ran the wires out through a hole in the front spar of the elevator via a grommet and it will
go up to the fuselage under or over the fin (I think, we haven't gotten that far yet). I would
cover the wires with heat shrink as they go up to the fuselage.
mbetti@up.net wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
--On that subject, where abouts does the wire exit the elevator to go to the fuselage? or stab?
On Thu, 03 Feb 2005 22:53:22 -0500, rebel-builders@dcsol.com said:-----------------------------------------------------------------Mike, we mounted ours on a rectangular plate that had a slight curve to
David A. Ricker
Canada
trim servo mounting
Would it come out by the control horns/center hinge of the elevator?
Mike Betti
771E
Sent: Friday, February 04, 2005 7:23 PM
Subject: Re: trim servo mounting
Mike Betti
771E
a grommet and it willMike
that far yet). I wouldgo up to the fuselage under or over the fin (I think, we haven't gotten
the fuselage? or stab?cover the wires with heat shrink as they go up to the fuselage.
theOn Thu, 03 Feb 2005 22:53:22 -0500, rebel-builders@dcsol.com said:Mike, we mounted ours on a rectangular plate that had a slight curve to
-------------------------------------------------------------------plate was attached via nutplates to the elevator. This was done for
David A. Ricker
Canada
trim servo mounting
Yep, that's exactly it.
Mike Betti wrote:
David A. Ricker
Canada
Mike Betti wrote:
--Would it come out by the control horns/center hinge of the elevator?
Mike Betti
771E
We ran the wires out through a hole in the front spar of the elevator viathat far yet). I wouldgo up to the fuselage under or over the fin (I think, we haven't gottenthe fuselage? or stab?cover the wires with heat shrink as they go up to the fuselage.
On that subject, where abouts does the wire exit the elevator to go totheOn Thu, 03 Feb 2005 22:53:22 -0500, rebel-builders@dcsol.com said:------------------------------------------------------------------------------------------------------------------------------------
David A. Ricker
Canada
David A. Ricker
Canada
