Shortening Elite elevator
Dear Builders,
While accomplishing the elevator horn modification, I am weighing whether to
shorten the elevator balance at each outboard end by three inches. Robin
Dyck said that this greatly improved handling on the Elite he flew, and it
is apparently a modification that MAM are thinking about doing.
Has anyone here done this? One approach has been to cut off the three
inches with a die grinder and use the end skin as a drilling guide in order
to reuse the ribs.
Shortening the flying surfaces seems like a big enough deal that I thought I
should ask around!
Best wishes,
Jeffrey Steenson
E714
to reuse the ribs.
should ask around!
Best wishes,
Jeffrey Steenson
E714
Hello Jeffrey
The Elite Dick is talking about is the Bob Gagne one. I do not know if use
that site but you can call him at 418-653-4953 (he speak english. He have
shortening them because the airplane was to sensitive on elevator and I
think he is happy with the result.
Jean
Rebel 747R
Sent: Sunday, January 30, 2005 6:29 PM
Subject: Shortening Elite elevator
Jean
Rebel 747R
Dear Builders,
order
to reuse the ribs.
should ask around!
Best wishes,
Jeffrey Steenson
E714
Yep, this is close to becoming a standard mod. for the Elite. You can just
cut the spades roughly in half span-wise - whatever leaves you with 5/16"
edge allowance on the central rivet hole. I have not yet flown my aircraft
(close though) so can't report personally on flying qualities. I did put a
doubler about 1 1/2" wide and 6" long under the skins, and put a doubler
over the junction of the two ribs about 6" long to compensate for lost
stiffness in the spade.
Al Hepburn
Al Hepburn
toDear Builders,
ordershorten the elevator balance at each outboard end by three inches. Robin
Ito reuse the ribs.
should ask around!
Best wishes,
Jeffrey Steenson
E714
I'm in the middle of building my elevator right now. It sure would be nice
to hear how this thread comes out before I finish. If I understand you,
won't this create a 3" space between the stab main spar and the elevator
balance? Is the space filled in?
Mike Betti
E771
Sent: Sunday, January 30, 2005 5:29 PM
Mike Betti
E771
toDear Builders,
Ito reuse the ribs.
should ask around!
Best wishes,
Jeffrey Steenson
E714
Would you have any pictures of this?
Mike Betti
E771
Sent: Sunday, January 30, 2005 6:32 PM
Subject: Re: Shortening Elite elevator
Mike Betti
E771
justYep, this is close to becoming a standard mod. for the Elite. You can
aircraftcut the spades roughly in half span-wise - whatever leaves you with 5/16"
a(close though) so can't report personally on flying qualities. I did put
whetherdoubler about 1 1/2" wide and 6" long under the skins, and put a doubler
Al Hepburn
Dear Builders,
Robintoshorten the elevator balance at each outboard end by three inches.
itDyck said that this greatly improved handling on the Elite he flew, and
thoughtorderis apparently a modification that MAM are thinking about doing.
inches with a die grinder and use the end skin as a drilling guide into reuse the ribs.
Ishould ask around!
Best wishes,
Jeffrey Steenson
E714
Thanks, Al, for your reply. Pictures would be great, because it is a bit
confusing. As I understand it, you have to shorten the spar and fiberglass
tip on the horizontal stabilizer accordingly to match.
13 hours on the elevator horn reinforcement mod ... now it's almost as
strong as Wayne's bullet-proof firewall mod!
Jeffrey
Sent: Sunday, January 30, 2005 5:37 PM
Jeffrey
Mike Betti
E771
justYep, this is close to becoming a standard mod. for the Elite. You canaircraftcut the spades roughly in half span-wise - whatever leaves you with 5/16"
edge allowance on the central rivet hole. I have not yet flown mya(close though) so can't report personally on flying qualities. I did putwhetherdoubler about 1 1/2" wide and 6" long under the skins, and put a doubler
Al Hepburn
Dear Builders,
While accomplishing the elevator horn modification, I am weighingRobintoshorten the elevator balance at each outboard end by three inches.itDyck said that this greatly improved handling on the Elite he flew, andthoughtorderis apparently a modification that MAM are thinking about doing.
Shortening the flying surfaces seems like a big enough deal that IIshould ask around!
Best wishes,
Jeffrey Steenson
E714
Merci, Jean, for Bob Gagne's number!
Sent: Sunday, January 30, 2005 5:20 PM
Hello Jeffrey
use
Jean
Rebel 747R
Dear Builders,
it
order
to reuse the ribs.
thought
should ask around!
Best wishes,
Jeffrey Steenson
E714
Guys
Let's get these pictures in the archive, I think every Elite builder is just
waiting to see how it looks and to have more feedback on how it flys.
Just so I understand this though, the mod is to trim the last 3" or so from the
width of the spade AND the elevator?
Anyone else heard about MAM thinking of making mods? Rumors? If we were going
to make changes it would be nice if MAM published the mod before we started
cutting..... BTW, this would be 3rd round of mods for our elevator and it
hasn't flown yet ;^(
Dave R.
Francine D.
elite583.cjb.net
Jeffrey Steenson wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
Dave R.
Francine D.
elite583.cjb.net
--Thanks, Al, for your reply. Pictures would be great, because it is a bit
Jeffrey
-----------------------------------------------------------------Would you have any pictures of this?
Mike Betti
E771
Al Hepburn
RobintoitthoughtorderI
David A. Ricker
Canada
to all Elilistis,
I flew Bob Gagne s Elite (after he made his mode) and the beast behave as
it should,extremely pleasant... we are modifiing ours at the moment
regards
gilles st pierre
e717
regards
gilles st pierre
e717
Date: Sun, 30 Jan 2005 19:32:56 -0500
Al Hepburn
whetherDear Builders,
toRobinshorten the elevator balance at each outboard end by three inches.itDyck said that this greatly improved handling on the Elite he flew, andorderis apparently a modification that MAM are thinking about doing.
inches with a die grinder and use the end skin as a drilling guide inthoughtto reuse the ribs.
Ishould ask around!
Best wishes,
Jeffrey Steenson
E714
i don t have is e mail add, but will call him to nigt and let you know
gilles
gilles
No, you chop the span off the outboard edge of the spade, then re-locate the
original tip ribs. Be sure to take care to maintain the alignment of the
spade or it can wind up twisted. Come to think of it, if you already have
the spade built, it would be a good idea to cleco the suggested 6" patch
that spans the roots of the ribs so you don't have to worry about alignment
so much. I'm going over to the shop tonight to work on the retracts, so
will try to get a couple of pix.
I don't recommend you do it this way, but it's just as if you put the
elevator in a table saw and lopped about 3 11/16" off each end!
Al Hepburn
Sent: Sunday, January 30, 2005 7:34 PM
Al Hepburn
whetherI'm in the middle of building my elevator right now. It sure would be nice
Mike Betti
E771
Dear Builders,
Ishould ask around!
Best wishes,
Jeffrey Steenson
E714
I would appreciate any pix on this matter. Do you cut off the spar and fibreglass tip of the stab to match also?
Mike Betti
771E
Mike Betti
771E
Al Hepburn
Mike Betti
E771
Dear Builders,
Best wishes,
Jeffrey Steenson
E714
Mike:
Sorry, I was at the shop tonight and fogot to photograph the elevator. I'll
try to remember at the weekend. However, I think you have the idea. The
fiberglass tips get shortened to match the spade, and the spar gets
shortened so it prortrudes to the point where the tip starts to curve from
horizontal to vertical.
The net result is that you lose about 5% of the total stab/elevator area. I
angonised for a long time about whether I should reduce the cord rather than
the span of the spade. I figured that by shortening the cord of the spade
by one third, I'd cut the moment it produces by a half, and wouldn't change
the total area at all. However, it would have been quite a bit more
complicated structurally, and since nobody had done it before, I'd be moving
more into test pilot role, so I finally grapped the snips and took the easy
route.
Sent: Tuesday, February 01, 2005 9:39 AM
route.
fibreglass tip of the stab to match also?I would appreciate any pix on this matter. Do you cut off the spar and
theThanks,
Mike Betti
771E
On Tue, 1 Feb 2005 07:38:08 -0500, rebel-builders@dcsol.com said:No, you chop the span off the outboard edge of the spade, then re-locate
haveoriginal tip ribs. Be sure to take care to maintain the alignment of the
alignmentthe spade built, it would be a good idea to cleco the suggested 6" patch
niceso much. I'm going over to the shop tonight to work on the retracts, so
Al Hepburn
elevatorto hear how this thread comes out before I finish. If I understand you,
andwhetherbalance? Is the space filled in?
Mike Betti
E771
Robinto
threeit
thoughtorderI
I'm planning on doing this mod this weekend. Robin says it's a good idea and
he is hoping some info will be available in a couple weeks, sounds like the
info is coming from Sean?? was getting it to Robin on what he done? Anyway,
Al seems to have the direction, just set your table saw fence to 3-11/16"
and run each side through, and your done..........
What is the best way to cut the skin off with out making a mess? Snips?
Cutoff wheel? I'm pretty early in this project and don't have all the
sheetmetal skills down yet. Does the doubler you added seem necessary?
Mike Betti
771E
Sent: Tuesday, February 01, 2005 6:38 AM
Mike Betti
771E
theNo, you chop the span off the outboard edge of the spade, then re-locate
alignmentoriginal tip ribs. Be sure to take care to maintain the alignment of the
Al Hepburn
andwhetherto hear how this thread comes out before I finish. If I understand you,
Mike Betti
E771
Dear Builders,
While accomplishing the elevator horn modification, I am weighingRobintoshorten the elevator balance at each outboard end by three inches.Dyck said that this greatly improved handling on the Elite he flew,
itthoughtorderis apparently a modification that MAM are thinking about doing.
Best wishes,
Jeffrey Steenson
E714
