rebel tail alignment
Jones, Michael
Post by Jones, Michael » Sat Feb 18, 2012 10:01 am
hi all
mounting my horizontal stab and after sundays meeting have few questions
about the alignment of all the tail components so here goes
1.dorsal fin, my fin is off set 3/4" as per the manual, when i install
dorsal fin i assume it aligns with the fin at the same angle to the centre
line of the fuselage or does it mount straight to centre line
2. horizontal stab fit, with my fin offset by 3/4" the front fin attach
bractet is now about 1/2" inch to the left of center, this now interferes
with the front horizontal stab mounting bracket about, you guesed it 1/2"
inch. the question here seems to be how far in towards the centre is the
horizontal stab bracket pulled ? i assume it should be flush with the
bulkhead it mounts to, or how close does the horizontal stab inner most rib
sit from the fuselage body ?
3. according to the manual the horizontal stab should have 1 deg of positive
incidence, no one seems to recall this and when i checked it on an actual
rebel it did not appear to be there, any comments
4. in the chapter for mounting the horizontal stab we are instructed to
level the plane using the main carry throughs, i assume this means level in
pitch and roll axis, so the tail must go up into the air
thanx for all help
mike#007
Post by Ken » Sat Feb 18, 2012 10:01 am
See embedded. My memory was indeed wrong in regards to the stab
incidence. A related msg is 29apr2000 from Richard DeCiero, subject-
fuse leveling. If its not in the archive let me know.
Jones, Michael wrote:
hi all
If you sight vertically then my stab inner most rib is flush with the
widest part of the fuselage at the bulkhead. The bolt that attaches the
stab to the bulkhead is 3.25" inboard from the widest part of the
bulkhead (and 2.75" lower than the very top of the bulkhead). Your
measurements are likely different but that's a general idea. The
distance between my stab inner rib and that attaching bolt hole is also
3.25" of course.
My bolt center is just over 3/4" from the closest corner of the bracket
that attaches the front of the rudder. That is on the closest side (left
side on mine) or the side that my rudder is offset on. It is closer than
I remembered but there is no conflict. The rear spar of my two stabs
form a straight line so no I didn't cheat ;)
OK be careful here. That is the forward edge of the stab one degree
higher than the rear edge of the stab (11/32" block). And note that is
11/32 (I used 5/16). It is NOT 11/16. We are more used to dealing with
16th of an inch than 32nds of an inch.
And my original manual says zero dihedral. That is the only thing that
you can easilly sight on a flying rebel. I don't believe there is any
way to tell if there is one degree of incidence by just looking.
Yes. See Richard's email.
thanx for all help
mike#007
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:01 am
#2..if your's is really that interfering Mike...trim it back and make a new
hole with the same edge distance as the original...remember only ONE bolt
per side or you turn that front spar into a cantilever beam..and that's not
what it's designed to be. Also do your self a favour and make something up
to hold both stabs in alignment at the rear spar, while you are locating the
front bolt hole. Easy to get them cockeyed...especially with your fin attach
off center and throwing you off. Measure from say your float point to the
outboard stab tip to check squareness.
#3 Manual does spell out 1 degree stab incidence with the cabin bottom
level. Do yourself a favour and make it 0.7 Degrees. That 0.3 will get rid
of the need for slight up elevator in normal flight.
#4 Yes cabin outer floor area level in fwd and side to side direction is
your "zero" point for wing dihedral and angle of incidence for stabs
To: "Rebel-Builders EMIAL (E-mail)" <rebel-builders@dcsol.com>
Sent: Monday, January 17, 2005 7:23 AM
Subject: rebel tail alignment
hi all
rib
positive
in
thanx for all help
mike#007
Jones, Michael
hi wayne
this confims direction i was heading, good idea to align stabs, might not
work for me in single car garage, will have to move some stuff to basment,
any thoughts on the dorsal fin, align with fin or fuselage, i assume with
fin
mike
Sent: Monday, January 17, 2005 12:55 PM
Subject: Re: rebel tail alignment
hi all
rib
positive
in
thanx for all help
mike#007
Would suggest that you want the dorsal fin straight in relation to the
fusleage. That 3/4" offset on the fin is already ?able. You sure dont' want
anymore offset surface..or you'll be holding left rudder all the time.
Others that have the dorsal fin on their Rebel please chime in! Wayne
Sent: Monday, January 17, 2005 1:44 PM
Subject: RE: rebel tail alignment
hi wayne
fin
mike
new
not
attach
hi all
centre
interferes
1/2"
rib
positive
actual
in
thanx for all help
mike#007
Post by Walter Klatt » Sat Feb 18, 2012 10:01 am
Yes, I have a dorsal fin on my Rebel. The vertical fin is offset
3/4 inch, but from there forwards, the dorsal fin is straight.
Seems to work just fine for me.
Not sure if the Rebel needs a dorsal fin. I have never flown
without one, but have been told that it also flies just fine
without one on floats. If I was doing it again, would probably
leave it off.
Sent: Monday, January 17, 2005 3:41 PM
relation to the
chime in! Wayne
hi wayne
fin
mike
it back and make a
new
not
attach
incidence for stabs
hi all
same angle to the
centre
centre line
center, this now
interferes
1/2"
rib
positive
checked it on an
actual
in
thanx for all help
mike#007
It may also be
may also be
intended recipient
FOKM flies fine without one ...as did Howard for about 5 summers before he
had me make up a removable ventral fin instead.
Some like the looks, some don't. Definitely should add some stability Mike,
but also adds more surface area for the x winds when on wheels.
Sent: Monday, January 17, 2005 8:26 PM
leave it off.
relation to the
chime in! Wayne
hi wayne
fin
mike
it back and make a
new
not
attach
incidence for stabs
same angle to the
centre
centre line
center, this now
interferes
1/2"
rib
positive
checked it on an
actual
in
It may also be
may also be
intended recipient
Schmucker, Del
Post by Schmucker, Del » Sat Feb 18, 2012 10:01 am
I have had mine both ways once with an offset and then later I changed
it being straight. This is both the dorsal fin and vertical stabilizer.
I couldn't really tell a difference either way. If you set it straight
it is very easy to either add a trim tab or add more rudder spring on a
side to control the yaw problem that the offset is for in the first
place.
Thank you,
Del Schmucker
Information Systems Manager
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Sent: Monday, January 17, 2005 7:33 PM
he
Mike,
leave it off.
relation to the
chime in! Wayne
hi wayne
fin
mike
it back and make a
new
not
attach
incidence for stabs
same angle to the
centre
centre line
center, this now
interferes
1/2"
rib
positive
checked it on an
actual
in
It may also be
may also be
intended recipient
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 10:02 am
The vertical and dorsal fin on my Rebel is straight and it flies true. Grant
and Brian, from MAM, told me the engine mount is now offset to help
compensate for the left yaw at full power and setting the vertical of 3/4" is not
nesses anymore. I did what I was told and it seems to fly straight in cruise at
75%.
Bruce
