Warp Drive Static RPM?
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from bc.sympatico.ca (a3a23400.sympatico.bconnected.net
[209.53.56.157])
by mail1-1.bctel.ca (8.9.1a/8.9.1) with ESMTP id QAA09264
for <murphy-rebel@dcsol.com>; Mon, 6 Sep 1999 16:55:39 -0700 (PDT)
Message-ID: <37D451BE.55515EF3@bc.sympatico.ca>
Date: Mon, 06 Sep 1999 16:43:59 -0700
X-Mailer: Mozilla 4.5 [en]C-SYMPA (Win98; U)
X-Accept-Language: en,fr-CA
MIME-Version: 1.0
To: "(Murphy Rebel)" <murphy-rebel@dcsol.com>
Subject: Warp Drive Static RPM?
Just testing my Warp Drive 3 blade wide tips prop
on a 150 HP Lycoming O320, and got 2300 RPM static
run-up. Is this too slow and should I take out
some pitch? My Rebel is almost ready for its first
flight, and I'm trying to get everything just
right.
Received: from enaila.nidlink.com (root@enaila.nidlink.com [216.18.128.8])
by lanfear.nidlink.com (8.9.0/8.9.0) with ESMTP id FAA18377
for <murphy-rebel@dcsol.com>; Tue, 7 Sep 1999 05:32:31 -0700 (PDT)
Received: from nidlink.com (pm5-12.nidlink.com [216.18.141.19])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id FAA20908
for <murphy-rebel@dcsol.com>; Tue, 7 Sep 1999 05:32:29 -0700 (PDT)
Message-ID: <37D5082C.788A69AB@nidlink.com>
Date: Tue, 07 Sep 1999 05:42:20 -0700
X-Mailer: Mozilla 4.5 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Re: Warp Drive Static RPM?
References: <37D451BE.55515EF3@bc.sympatico.ca>
Content-Type: text/plain; charset=x-user-defined
right.
How much pitch do you have? At the tips please. You will need about 13
or so. Degrees that is.
Dave Bangle http://www.subielyc.com/
[209.53.56.157])
by mail1-1.bctel.ca (8.9.1a/8.9.1) with ESMTP id FAA08333
for <murphy-rebel@dcsol.com>; Tue, 7 Sep 1999 05:57:13 -0700 (PDT)
Message-ID: <37D50B77.DB755C11@bc.sympatico.ca>
Date: Tue, 07 Sep 1999 05:56:23 -0700
MIME-Version: 1.0
I didn't have my protractor with me when I did my run-up, but I think it was
around 11 1/2 degrees. I am going to check it again tonight or tomorrow.
Also, it is a 3 blade 72" diameter wide tip prop. I am sure it is not 13"
pitch, though. My O320 is 150 HP, not 160 either. Peak HP is at 2700 RPM.
right.
Received: from dialup.voyager.co.nz (ts1p13.net.ashburton.voyager.co.nz
[203.21.25.177])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with SMTP id IAA23068
for <murphy-rebel@dcsol.com>; Wed, 8 Sep 1999 08:50:24 +1200 (NZST)
Message-ID: <004001bef972$85d0e380$b11915cb@dialup.voyager.co.nz>
Date: Wed, 8 Sep 1999 08:47:04 +1200
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Hi,
My 150HP 0-320 Rebel with about a 74-58 Sensenich metal prop static is
2300rpm.
This is what I would call a cruise prop. It works fine. About 105Kt cruise
at 2400rpm.
I would prefer a climb prop so I am going to repitch to aim for a static of
about 2500-2550rpm
Alister
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Date: Wednesday, September 08, 1999 12:57 AM
was
right.
[209.53.56.157])
by mail1-1.bctel.ca (8.9.1a/8.9.1) with ESMTP id UAA11065
for <murphy-rebel@dcsol.com>; Tue, 7 Sep 1999 20:07:21 -0700 (PDT)
Message-ID: <37D5D336.D9EC6043@bc.sympatico.ca>
Date: Tue, 07 Sep 1999 20:08:39 -0700
MIME-Version: 1.0
References: <004001bef972$85d0e380$b11915cb@dialup.voyager.co.nz>
Thanks Alister. I would also be interested in what Warp Drive users are
getting
for a static RPM. I just confirmed today that my pitch is set at 11 1/2
degrees. Some time ago, I heard or read somewhere that the static RPM for
Warp
Drive props should be higher than for metal props. I seem to recall
something
about there being more flex and that was the reason.
Alister Yeoman wrote:
Hi,
2300rpm.
at 2400rpm.
about 2500-2550rpm
Alister
was
13"
subersys wrote:
Walter Klatt wrote: How much pitch do you have? At the tips please. You will need about
13
by lanfear.nidlink.com (8.9.0/8.9.0) with ESMTP id CAA15625
for <murphy-rebel@dcsol.com>; Wed, 8 Sep 1999 02:08:25 -0700 (PDT)
Received: from nidlink.com (pm5-23.nidlink.com [216.18.141.30])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id CAA27653
for <murphy-rebel@dcsol.com>; Wed, 8 Sep 1999 02:08:23 -0700 (PDT)
Message-ID: <37D629D7.DC0516B5@nidlink.com>
Date: Wed, 08 Sep 1999 02:18:16 -0700
MIME-Version: 1.0
getting
Warp
something
In my inquiries Walter it appears the 160 users are getting 2350 at 13
degrees. Your setting sounds about right for the 150 HP version. FWIW
I get 2380 with 14.5 with my Subaru. All are 3 blade. You might check
with Warp Drive about problems. Seems some of the blades are cracking
with use on the o320. They will know the problems and the answers.
Post by Walter Klatt » Fri Feb 17, 2012 5:26 pm
Thanks for the info, Dave. Not sure what HP you have on your Subaru, but
sounds like
it beats the O320. I spoke to Warp Drive today and he said people were using
anywhere
from 9 to 12 degrees pitch with the 150 HP depending if they were on floats
or wanted
cruise power. The suggested static RPM was 2300 - 2400, so mine at 11 1/2
and 2300
should be a good place to start. He also mentioned that there were no
problems with
the 150 HP users, just the high compression guys, so hopefully I don't have
to worry
about that.
