Moose Wing Construction/ wide spades
Al Paxhia
Post by Al Paxhia » Sat Feb 18, 2012 9:53 am
I changed from small to large spades after 45 hours, it was well worth it,
much lighter controls. The story I heard was the original design of the SR
had 12" spades as did the Elite.In testing the Elite with large spades it
had an aileron reversal problem so the spades were reduced to 6". At that
time the SR had not been built so the spades were made smaller. Flight
testing the SR showed that it needed a larger spade, thus the upgrade.
Al
Sent: Tuesday, December 14, 2004 5:49 PM
Subject: Re: Moose Wing Construction
It's for both to lighten the stick forces. Optional but according to most
that have done it well worth it. Guys chime in that are flying
with/without
the wider spades!
Sent: Tuesday, December 14, 2004 8:53 PM
Wayne is this mod for just the super rebels or is it done on the moose
application also. Figured I better ask since I will be getting to them
in
the near future. Thanks Dale
Sent: Tuesday, December 14, 2004 8:34 PM
You've got to cut/paste that line right to the .pdf to make it work or
go
MAM's site..Moose Tech and bottom left corner you'll find the aileron
mod
available icon.
Looked thru my pictures of the SR wing build and while I have three
shots
all 6 spars laid out across the bench.... none show the overlap detail
well
enough to be of any help #&#!)*(
Sorry,
Sent: Tuesday, December 14, 2004 8:25 PM
http://www.murphyair.com/SUPPORT/Mods/S ... 0ENHANCEME
anything...just
extensions
