I was putting together my 1000th order with Aircraft Spruce and noticed that
they don't sell alclad 6061. Only 2024 is available alclad. Am I mistaken.
Isn't alclad 6061 most of what MAM provides? Does anyone know if MAM
provides T4 or T6 6061? OK, why don't I get to the bottom line. I want to
buy the best stuff for my cowl. Alclad 6061T6 because of 6061's better
corrosion resistance, and the T6 is the highest level of conditioning
(hardest tempering)? But 2024 is supposed to be better for fatigue
resistance. Watcha think? 2024 or 6061? Just annealed or heat treated as
well? Since heat treating hardens the metal does that reduce fatigue
resistance? Perhaps the alclad 2024T3 would be best since it is best for
fatigue resistance, is only moderately hardened, and the alclad improves
corrosion resistance.
Lastly, I can get sheets rolled and shipped normally (i.e., not freight) up
to 0.032 thickness. I was planning on using 0.025. I figured on four 3 X 4
foot pieces for each of the four cowl panels. Sound about right?
Mike Kimball (being picky)
044SR
Alclad 6061?
Alclad 6061?
Mike...6061 generally comes in "bare" state only. It is not alcad'd like
2024 to protect the pure metals in 2024. What MAM ships and what is readily
availabe it 6061-T6 Bare.
As for what to make the cowling doors out of...probably not a big difference
going either way (other than 2024 is double the price!). My doors are 2024
T3 and only because that is what MAM supplied in the fwf kit for the O-235
at the time in 1993. Others I've had in the yard have 6061-T6 doors and
don't/didn't exhibit any signs of fatigue.
Can't help you on the sizes you need.
To: "Rebel List" <rebel-builders@dcsol.com>
Sent: Saturday, December 11, 2004 3:29 PM
Subject: Alclad 6061?
thatI was putting together my 1000th order with Aircraft Spruce and noticed
mistaken.they don't sell alclad 6061. Only 2024 is available alclad. Am I
toIsn't alclad 6061 most of what MAM provides? Does anyone know if MAM
asbuy the best stuff for my cowl. Alclad 6061T6 because of 6061's better
upwell? Since heat treating hardens the metal does that reduce fatigue
4to 0.032 thickness. I was planning on using 0.025. I figured on four 3 X
044SR
Alclad 6061?
G'day Mike ;
6061 is NOT an "alclad" aluminium - because it doesn't need to be !
..... 2024 IS because it has crappy corrosion properties & the "alclad"
gives it a skin of resistant aluminium to protect the underlying - more
exotic mixture.
YES ... 2024 IS stronger than 6061 .... but MAM designed their a/c
around the strength characteristics of 6061 .... and 6061 is an
"exterior grade" alloy ... they make aluminium truck bodies / chassis
out of 6061 ... but they don't make 'em out of 2024 !
Rick Harper
541R
PS I'm not a nerd speller .... "Aluminium" is what the whole WORLD
(minus America) calls it .... because that IS its name ... discovered by
a French chemist in 1825 - refined to basically it's present basic
formula (less the modern and exotic additives) by a German in 1840 ...
and THEY named it ALUMINIUM .....
AL - YOU - MIN - EE - UM
To: Rebel List
Sent: Sunday, December 12, 2004 7:29 AM
noticed that
mistaken.
want to
better
treated as
for
improves
freight) up
3 X 4
044SR
exotic mixture.
Rick Harper
541R
To: Rebel List
noticed that
mistaken.
want to
better
treated as
for
improves
freight) up
3 X 4
044SR
Alclad 6061?
After living in Australia for a few years I grew used to calling it
auluminium after a while. But I've been back in the US for 8 years now.
Apparently, I simply adapt to where I'm at after enough time has past. I'm
afraid it's a-loo-mi-num for me again.
A web search showed me that alclad 6061 is out there. But it's not common.
I'll probably just go with 6061-T6 since the whole rest of the airplane is
made of that.
Rick Harper
Sent: Saturday, December 11, 2004 12:07 PM
Subject: Re: Alclad 6061?
G'day Mike ;
exotic mixture.
Rick Harper
541R
To: Rebel List
noticed that
mistaken.
want to
better
treated as
for
improves
freight) up
3 X 4
044SR
made of that.
Rick Harper
G'day Mike ;
exotic mixture.
Rick Harper
541R
To: Rebel List
noticed that
mistaken.
want to
better
treated as
for
improves
freight) up
3 X 4
044SR
Alclad 6061?
Bewdy !
Sent: Sunday, December 12, 2004 9:54 AM
Subject: RE: Alclad 6061?
now.
I'm
common.
airplane is
made of that.
Rick Harper
G'day Mike ;
"alclad"
more
exotic mixture.
Rick Harper
541R
by
To: Rebel List
noticed that
mistaken.
MAM
want to
better
conditioning
treated as
fatigue
best
for
improves
freight) up
four
3 X 4
044SR
now.
I'm
common.
airplane is
made of that.
Rick Harper
G'day Mike ;
"alclad"
more
exotic mixture.
Rick Harper
541R
by
To: Rebel List
noticed that
mistaken.
MAM
want to
better
conditioning
treated as
fatigue
best
for
improves
freight) up
four
3 X 4
044SR
