Fuel Starvation and "flop tubes" ? - Thanks
N.Smith
Post by N.Smith » Sat Feb 18, 2012 9:46 am
Thanks Both
Just planning ahead a bit...still got to finish the Fus and get it out of
the shed before I have space to start on the wings.
Thanks again
Nig
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: 28 November 2004 16:04
Subject: Re: Fuel Starvation and "flop tubes" ?
Hi Nigel !
Al is right - just buy another 5 gallons !!! ;-)
....... and just get it flying !!!!! :-)
Header tanks are almost always unnecessary and BAD NEWS !!
I lost a good friend because the header tank under the panel split open,
drenching him - and the hot exhaust manifold - with fuel !!! (Super Cub)
I've flown all kinds of Murphy aircraft, with all kinds of different
variations on the fuel system, in all kinds of extreme attitudes, and
NEVER had a fuel flow problem !! I can't say that about several
certified aircraft i've flown & owned ....
I have deliberatley run a tank completely dry in flight - by flying
with that wing raised to drain the last drop out. I just leveled the wings,
turned that tank off, and turned on the other side - the engine hadn't
stopped
windmilling, and just picked right up and I flew home & landed. I wanted
the tank dry so I could replace the sight guage tubing, which had been
discoloured by bad gas. If anyone worries about this, just add a fuel valve
from a Renegade to the bottom of the sight guage tubes - these are small
1/8" valves, that will allow you to shut fuel out of the guage in the
event of leaks or discolouration...
Keep rivetting - it IS worth it !!! ;-) :-)
...........bobp
On Sunday 28 November 2004 09:06 am, N.Smith wrote:
Hi All
I remember a thread a few years ago about fuel starvation with fairly
extreme nose pitch up and down attitudes and lowish fuel contents.
A local Maverick I looked at recently has a small header tank located just
behind the pilots head to prevent this happening. (not sure if this is
standard in a Maverick or not).
Has anyone experienced this problem in a Rebel / Elite, and any thoughts
on
installing a "flop tube" (INVERTED PICKUP TUBE) in each wing, my thoughts
being if fuel contents where low the tube would travel with the fuel and
hopefully remain in it ?
I've never seen one of these flop tubes so it might not be suitable at all
- just wondered ?
Nigel
745E
