Angus is coming, with video & still shots from his trip - hope we can
use the big TV !!
See you there !
........bobp
On Thursday 25 November 2004 07:25 pm, Ken wrote:
Yes it is a good idea but it gets ugly fast though. A separate lever on
a fulcrum to clear the aileron push tube and increase the leverage and
throw. Allowing for reflex. Getting it low enough to to not get severely
"goosed" while entering the cockpit. However if it wasn't for that
horizontal aileron push tube....
Naw - what Bob P. said - I'm leaving mine as it is (according to the
manual)!
Bob I should be at the meeting Sunday. If nobody has a better idea, I
could talk for a couple of minutes on simple low voltage warning devices
and overvoltage protection if you want.
Wayne G. O'Shea wrote:-----------------------------------------------------------------Damn Jesse.....that's just too darn simple...why would we want to take the
easy way out???? ) BUT you're probably right...with the right shape to
get it below the door sill you could probably do just that with a pegging
plate at the front door post for each position. Worth looking at for
sure!...but would be a pretty long "handle" so to make it flex free it
would have to be pretty stout.
Sent: Thursday, November 25, 2004 1:26 PM
Subject: Re: Flaperons - Rebel
soundsI havn't studdied the control setup very much, so forgive me if this
stupid, but what about just creating a "Johnson bar" setup by simply
extending the mixer arm all the way forward between the seat and
sidewall? That way you would have a linkage/slop-free system that would
allow you to directly change the position of the aileron bellcrank. Has
anyone tried it that way? I will probably build mine standard anyway,
but just thought I would bring it up.
Jesse Jenks
#758
