Strengthening for 0320, Elite Instrument Panel
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from dbis.ns.ca (ts1-12.hfx.dbis.ns.ca [24.222.28.44])
by shenzi.dbis.ns.ca (8.9.3/8.9.3) with ESMTP id XAA08330
for <murphy-rebel@dcsol.com>; Sat, 21 Aug 1999 23:05:40 -0300
Message-ID: <37BF5B7B.BF9D0C3D@dbis.ns.ca>
Date: Sat, 21 Aug 1999 23:07:55 -0300
Organization: .
X-Mailer: Mozilla 4.06 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Re: Strengthening for 0320, Elite Instrument Panel
References: <v04003a01b3e36a0dbf77@[205.163.8.199]>
Can you tell me more about this "curved" instrument panel in the Elite? We
have
an early Elite, #583 which has given us a few headaches with part
discrepancies
(parts not matching the manual or incompletely fabricated) and I am
wondering if
we have the right (non curved) panel. After seeing Ken Armstrongs article
on the
Elite in Kit Planes I asked Murphy and they said we had the right part.
Your
comment makes me suspect we do not.
While on this subject, I am struck with the lack of panel space in the Rebel
Elite, what is the opinion of the completed Rebel owners? Is there enough
room
for a good VFR setup? How about IFR?
Dave R.
Elite #583
Dave Klimas wrote:
Alister,
We sure enjoy hearing from you and your "field testing" experiences.
I also will be installing the spring gear with an O320 engine and would
very much like to incorporate some of the enhancements that seem
reasonable
while I am in the construction stage.
Do you have the standard or Elite style curved instrument panel? How thick
was the upper panel that cracked?
If you would be so kind as to summarize the "mods" you have determined to
be necessary I would be most appreciative.
Thanks again for your posts.
Dave Klimas
Ramona, CA
Rebel #472
Brian,
The flying is going just great, I have clocked up over 160hrs
now. What a neat little aircraft!
Even with a cruise prop I can pull very big loads out of very small
areas, a
very useful aircraft.
The strengthening mods I did around the gear area are working really
good,
no problems in that area now.
I found another problem though.
Cracks started to appear on the instrument panel, on checking, they were
coming from a mis-directed load path. When taxiing ( when heavy) on rough
ground the panel in front and on top of the instrument panel used to pant
(flex) on either side just in front of where the instrument panel bends.
It
finally cracked in this area. ( this was hidden by upholstery)
I had to remove the windscreen and reinforce the area including the top
engine mounts.
I have no doubt that the problems I have experienced come from hanging
off
heavier and heavier motors without increasing the skin thickness and
design
up front to compensate. ( Didn't the Rebel start with a 582?)
I also operate off sometimes very rough strips. ( a lot off these were
put
in in the old deer meat recovery days, they are cut out of riverbeds and
are
ROUGH!) Murphy says ' sorry, but it appears you are doing the forward
field
testing for these types of operations', They are probably right, they
say
that over there that the majority of Rebels that operate in the outback
would be on floats. Floats can be very hard on a fuse as well but the
load
paths are very different.
However, I really do feel that I am getting to the point where I am on
top
of this ( I hope those aren't famous last words!).
If you are running an 0320 and spring gear and intend to operate out of
unimproved strips it would pay to have a think about it.
Alister
Date: Friday, August 20, 1999 1:17 AM
Subject: Re: c of g
Hi Alister
Sorry if I confused/misled you about my empty C of G. With 2 pilots &
3/4
fuel my the C of G is
about 16". My empty C of G is 11.6".
How is the flying going? Spring gear OK?
Best Regards
Brian #328R
:08 PM 19/08/99 +1200, you wrote:
have
movement
wheels
factory
heard
weight,
those
up
keeping
it
have
softer
will
flights,
ballast,
lots.
would
be
g
an
should
all,
difference!
G
is
course,
forward
have
16.8"
all.
adjust
worth
on
experience
meeting
how
Ej22
build
firewall
of g
David A. Ricker P. Eng.
Fall River, Nova Scotia
Canada
ricker@dbis.ns.ca
Received: from [205.163.8.199] (drk.cts.com [205.163.8.199])
by neko.cts.com (8.9.3/8.9.3) with ESMTP id NAA07602
for <murphy-rebel@dcsol.com>; Sun, 22 Aug 1999 13:06:27 -0700 (PDT)
X-Sender: drk@crash.cts.com
Message-Id: <v04003a03b3e594d8b30f@[205.163.8.199]>
In-Reply-To: <37BF5B7B.BF9D0C3D@dbis.ns.ca>
Mime-Version: 1.0
Date: Sun, 22 Aug 1999 13:06:30 +0100
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Dave,
The standard Rebel instrument panel is rectangular and about eight (8)
inches tall. The curved Elite panel is an option for the Rebel and is the
same height at the outer ends where it is secured to the vertical uprights
but the top edge gently curves up to about eleven (11) inches in the
center. It still has the straight jogs forward at about seven (7) inches
from each mounting end.
Hope this answers your question.
While I haven't placed any instuments in my panel as yet, preliminary
measurements indicate that there is room for a nice simple IFR setup. The
basic six plus GPS-Comm, NAV-Comm, Transponder, Engine Monitor and various
switches, breakers, and indicators.
Dave Klimas
Ramona, CA
Rebel #472
We have
discrepancies
wondering if
on the
Your
Rebel &
room
Dave R.
Elite #583
Dave Klimas wrote:
Alister,
reasonable
thick
Dave Klimas
Ramona, CA
Rebel #472
Brian,
areas, a
good,
rough
pant
It
engine mounts.
off
design
put
and are
field
say
load
top
Alister
Subject: Re: c of g
3/4
20
have
movement
wheels
factory
heard
..... weight,
those
pounds up
keeping
it
firewall
have
softer
more), and
move the
will flights,
ballast,
degrees of
lots.
would
be
g
tail
has an
should
all,
difference!
G
is
course,
forward
1
have
guy).
16.8"
all.
adjust
worth
feel on
experience meeting
recall how
[/quote]Ej22
[/quote]the
build
[/quote]firewall
[/quote]and
of g
[/quote]the
Canada
ricker@dbis.ns.ca
[/quote]
Received: from dbis.ns.ca (ts1-04.hfx.dbis.ns.ca [24.222.28.36])
by shenzi.dbis.ns.ca (8.9.3/8.9.3) with ESMTP id JAA01707
for <murphy-rebel@dcsol.com>; Mon, 23 Aug 1999 09:30:02 -0300
Message-ID: <37C13F51.6EB530AD@dbis.ns.ca>
Date: Mon, 23 Aug 1999 09:32:17 -0300
Organization: .
MIME-Version: 1.0
Looks like our Elite came with the "standard" Rebel panel, suppose we'll
have to
talk to Murphy about it if we want the bigger one. The only difference
though
appears to be the curved centre section (for more panel area).
Dave R.
Dave Klimas wrote:
Dave,
Dave Klimas
Ramona, CA
Rebel #472
We have
discrepancies
wondering if
article
on the
Your
Rebel &
enough
room
Dave R.
Elite #583
