place. Any thing..proseal, RTV etc would do.
The single 3/8" leg retainer bolt I put the nut on the outsid..... where
it's easy to properly torque. The saddle bolts probably have some merrit
going in from below as if you stripped a nut in a hard arrival the bending
bolt might crate enough friction to hold you up somewhat to negate a prop
strike.....although it definitely will add a bit of work to switching over
to the float brackets like you have envisioned!
Sent: Tuesday, November 23, 2004 12:55 PM
Subject: Elite Spring Gear crush tubes & compression block question
compressionHi All
Just a quick question about the spring gear compression tubes SG-10 and
compression block SG-5 that surround the AN5 and AN6 bolts holding on the
gear legs inside the FUS 5 carrythrough's.
The manual shows the bolts going in from underneath, with the nut on the
top.
My question is has anyone had a problem when changing from spring gear to
floats or the other way round and whilst the bolt is removed the
wastubes or block move and cannot be relocated around the bolt. If the bolt
ismounted from above the nut could be removed and the bolt left more or less
in place lying through the fuselage so the tubes remain located correctly.
The other option may be to "glue" the tubes in position before the floor
rivetriveted down ?
Ideas, or am I just worrying about a non event (hopefully starting to
the floor down later tomorrow so thought I'd check :-)
Nigel
745E
