Ryan, the M14 carburetor already has an internal spring that opens the
throttle. At least Steve's (who showed me this) and mine do. It seems to
be plenty strong to open the throttle, especially with the air flow coming
in, in-flight.
FWIW,
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ryan
Mowat
Sent: Friday, November 05, 2004 8:30 AM
Subject: Throttle Spring
Just want to know what the popular opinion is for installing throttle
springs on engine the engine throttle - in the event that the throttle cable
were to relieve itself of its duty the spring would cause the engine to run
a full throttle rather than idle. I am thinking full throttle is easier to
deal with then idle?
Which is better - sring to full throttle or no spring and idle when cable
fails?
Throttle Spring - M14
Thanks, I added a small one to give it a little extra.
Ryan Mowat, P.Eng.
30528 1A Greatnorthern Ave
Abbotsford, BC V2T 6H4
(604) 556-7222 (ext 307), (604) 556-7215 (Fax)
Scott Aldrich
Sent: Wednesday, November 17, 2004 9:06 AM
Subject: RE: Throttle Spring - M14
coming
in, in-flight.
FWIW,
Scott
Ryan
Mowat
cable
run
cable
fails?
Ryan Mowat, P.Eng.
Scott Aldrich
coming
in, in-flight.
FWIW,
Scott
Ryan
Mowat
cable
run
cable
fails?
