Just want to know what the popular opinion is for installing throttle
springs on engine the engine throttle - in the event that the throttle cable
were to relieve itself of its duty the spring would cause the engine to run
a full throttle rather than idle. I am thinking full throttle is easier to
deal with then idle?
Which is better - sring to full throttle or no spring and idle when cable
fails?
Throttle Spring
Throttle Spring
Mine is spring loaded open. If I had a mixture control, I'd make sure it
was the same - . There are lots of ways to shut off an engine but no
other way to open the throttle if the cable disconnects.
I guess it might be tougher to deal with quickly if it went to full
throttle on the ground but everything has tradeoffs.
fails?
Throttle Spring
FULL THROTTLE ! you can always turn it on and off to control power. Idle is
useless for anything unless you're still taxing on the lake!
Sent: Friday, November 05, 2004 10:29 AM
Subject: Throttle Spring
cableJust want to know what the popular opinion is for installing throttle
runwere to relieve itself of its duty the spring would cause the engine to
toa full throttle rather than idle. I am thinking full throttle is easier
fails?
