fuel tank construction/ maint
Andy Bowman
Post by Andy Bowman » Sat Feb 18, 2012 9:40 am
Hello,
i have an aluminum welded fuel tank that was leak tested extensively prior to installation. it was rewelded to cure a few small leaks and retested and installed. after 15 months of use with av gas, it has started to leak rapidly from a lower seam after all those months. it has had fuel in it for 100 percent of that time.
my question is do you rebel guys rely on your prosealed seams or do you "slosh" your tanks also?
we may be able to proseal the lower seams through the fuel filler, but it will be a less than pretty result. our other possibility is to pull the wing and slosh the tank. i guess we could also try sloshing with the wing installed as the leak is definitely in a seam on the bottom of the tank.
any thoughts or suggestions would be very appreciated. we use av gas in the wing tanks and blend with auto fuel in the main fuselage tank. anyone have experience with sloshing materials and there success/failure with av or auto fuel?
thanks
Andy
Do you Yahoo!?
Check out the new Yahoo! Front Page. www.yahoo.com/a
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:40 am
Do not slosh...just a ticking time bomb! (no matter what it says on the
can!)
Pull the tank..reweld if necessary to tie the crack back together and then I
would prep the entire welded seam area and an inch or so beyond with a heavy
scotchbrite disc, clean and proseal the entire seam overlapping an inch or
so out onto good clean alum.
I've done this routine for years on Zenair's porous welding of all their 601
and 701 fuel tanks with great success. Never had one leak after this
treatment.
Sent: Thursday, November 04, 2004 9:47 PM
Subject: fuel tank construction/ maint
Hello,
or auto fuel?
thanks
Andy
Do you Yahoo!?
I also re-read that Andy and doesn't sound like removing the tank is an
option of choice.....unfortunately I cannot see how you can prep and clean
the area thru the filler neck to then go in there and spread proseal over
it. If it's not cleaned and prepped properly...no different than doing body
work and paint...don't bother prosealing as it won't stick and then you'll
have an even bigger mess to deal with.
Sent: Thursday, November 04, 2004 9:51 PM
Subject: Re: fuel tank construction/ maint
can!)
heavy
601
treatment.
Hello,
prior
for
it
wing
or auto fuel?
thanks
Andy
Do you Yahoo!?
Post by Ken » Sat Feb 18, 2012 9:40 am
The PRC rep was pretty frank with me and said sloshing was a temporary
repair as far as he was concerned.
There was an interesting site documenting fuel tank testing from one of
the manufacturers that I perused once. They had a rock and roll machine
set up to simulate flight. The conclusion was that any split seams or
cracking was almost certainly caused by flexing of the tank as fuel
sloshed around. If you think that is the case then a welded sean will
crack again in the same time or sooner. You might want to consider a
design change or at least adding baffles instead of just welding the
seam...
I doubt that proseal will stop the crack from progressing if it is a
split seam.
Andy Bowman wrote:
Hello,
thanks
Andy
Do you Yahoo!?
Andy Bowman
hi,
Thanks for your suggestions. we doubt that the fuel is moving a lot as we have a 7 gallon
tank that is one rib bay wide on a Christavia mk-1. our floats are 1800 amphibs and thus our interest in your group. the tank is therefore narrow, and due to weight and balance considerations has been kept full and in fact not used much in flight except for testing purposes. the leak appears to be on a lower side seam as the rear lower seam is a bend, not a welded seam. the flow is not coming from the fuel line fitting or the quick drain. the flow from the leak is fairly substantial. it will cause regular dripping from three seaplane grommets simultaneously.
as Wayne deduced, pulling the wing and then the tank from the wing does not sound like fun to us. the wing is all wood structure, fabric covered, and rib stitched. the paint is aerothane so patching in the hole we'll have to cut will probably require another coat or two of finish color.
we were fairly sure that the cure for this problem would include some less than fun stuff.
the welder is a very experienced tig equipped friend who did all three of our tanks .
my temptation is to pull the wing, open up an access hole in the fabric, open and access hatch in the tank top, and proceed to clean prep and proseal the lower seams in the tank. then I'd try to patch up the entry wounds as best i can and reassemble. i think we will fly as is with three hour of fuel instead of four until our water turns rock hard and then take her down for the repair.
any thoughts on this course of action? anyone ever had the joy of pulling a wing off a plane way up on those floats?
thanks again.
Andy
Do you Yahoo!?
Andy, most of the Super Cub (cert and homebuilt) guys end up making an
aluminum cover for the tank area once they pull the tank the first time (of
many) to get away from redoing fabric. Might be an option for you so you can
take the tank right out!?
As for removing a wing when way up there...yes and I do it all by myself! I
have a walk behind pallet lift. I extend the forks using 4" ABS sewer pipe,
then I lay a twin mattress across the forks..lift up into place and then
remove the lift struts and then unbolt the wing. Slide the wing over enough
to clear the fuselage and then lower.
Good luck,
Sent: Friday, November 05, 2004 9:38 AM
hi,
have a 7 gallon
than fun stuff.
our tanks .
the repair.
thanks again.
Andy
Do you Yahoo!?
Barnhart
Post by Barnhart » Sat Feb 18, 2012 9:40 am
Andy,
A couple of us were having problems with leaking around the stringers and
the lower part of the front spar. Pulled the top tank skin, and "sloshed"
every part of the tank except for the upper tank skin. It took care of the
problem. Jeffco isn't cheap but doesn't add much weight. Aircraft Spruce
sells it.
Barny
SR103 MGDQ 20bt
Sent: Thursday, November 04, 2004 9:48 PM
seam...
split seam.
Andy Bowman wrote:
Hello,
or auto fuel?
thanks
Andy
Do you Yahoo!?
_____________________________________________________
This message scanned for viruses by CoreComm
