Corrosion proofing.
Corrosion proofing.
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from ne.com.au (tc1-36.ne.com.au [203.13.72.228]) by
redback.ne.com.au
(8.8.7/8.7.3) with ESMTP id WAA01836 for <murphy-rebel@dcsol.com>; Fri, 20
Aug 1999 22:34:15
+1000
Message-ID: <37BD4BC4.E04A068@ne.com.au>
Date: Fri, 20 Aug 1999 22:36:20 +1000
X-Mailer: Mozilla 4.05 [en] (Win95; I)
MIME-Version: 1.0
To: "(Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Corrosion proofing.
G'day From Australia
I have a few questions regarding corrosion proofing that I would
appreciate some help on, and they are;
1 Just what must be done to clean the parts that form part of the
internal structure before chromating?
2. Can the zinc chromate be brushed on or must it be sprayed?
3. How thick should the coat be?
4. Can the parts be assembled wet or must the chromate be dry?
5. Is there any value, or in fact any need, to chromate the entire
internal structure?
6. When I finish the factory supplied chromate, could I use other
brands? Compatibility?
7. Should the fuselage be fully chromated internally? And if so at what
stage?
8. Should the skins be chromated externally, where the rivets will go,
before assembly, so that there will be chromate under the rivet?
Thanks and regards
Ian Donaldson
Corrosion proofing.
Received: from albedo.net (ppp123.albedo.net [206.51.22.142])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id JAA03979
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 09:06:18 -0400
Message-ID: <37BD51B9.E05FBD78@albedo.net>
Date: Fri, 20 Aug 1999 09:01:45 -0400
X-Mailer: Mozilla 4.08 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Re: Corrosion proofing.
References: <37BD4BC4.E04A068@ne.com.au>
I just scotch brite and wipe with MEK or acetone.
I just brush during assembly. Thin the chromate.
Very thin is as effective as thick and less prone to flaking off generally
but I
use enough 'fill' the joints to keep moisture out.
I prefer wet. It adds a little strength and keeps moisture out.
internal structure?
I did a light spray inside fuselage as cessna's eventually corrode roof and
floor due condensation and leaks. Will just spray corrosion-X or ACF-50 in
wing
after painting. Believe most people do neither as 6061 is fairly corrosion
resistant. I was seeing surface corrosion though on my unfinished 7 year old
fuselage which is stored in an unheated shop in a humid climate.
Believe anything is 90% as good as the best but I am sticking with the epoxy
chromate. Price varies widely depending on source.
stage?
see above. If I were planning salt operations I would spray inside of all
panels
before assembly.
before assembly, so that there will be chromate under the rivet? I like to
dip the rivets
and install wet but I am not consistant. This also helps seal the rivet so
water can't leak
in I believe.
I have not used alodyning anywhere. For exterior skin prep I was very
pleased
with advice received here. Scotchbrite, scotchbrite with metal prep, rinse
with
hose, dry in sun with hvlp air pressure to blow out water, spray epoxy
primer.
The metal prep worked very well with no alodyning.
