Moose - tail dragger handle kit
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 9:35 am
I just installed the optional tail handler kit on my moose. MAM's picture
instruction show installing it below the center rivet line. If you do it
overlaps the side skin crease line and looks crappy. I removed two rivets
from the center row and installed it centered vertically. Depending on how
you did your elevator cables you need to make sure you have clearance with
the cables. Maybe that is why they put theirs low, not sure.
Another hint, if your elevator cables are already installed make sure they
are back on top of the handle tube before you do the final rivet...I love
doing everything twice.
Scott
Moose 174
