MURPHY 3500 Ventral Fin Plan
Don Boardman
Post by Don Boardman » Sat Feb 18, 2012 9:34 am
Hi bb44bb,
If you are going to put her on floats you may will want to consider the
installation of a ventral fin. The fin may share a few rivet locations at
the rear underside of the fuselage. Something to think about. When I
installed mine from Montana Floats I had to drill out a few rivets and
carefully locate the fin to interfere the least with existing rivets.
Regards,
Don Boardman
& Partner, Randy Bowers
N622D Double Duce Delta Moose
#130 M-14PF 400HP, MT-Prop/Beta, Aerocet 3500 amphibs
Delta Lake, Rome, NY
I JUST STARTED THE BOTTOM OF THE FUSELAGE OF A MOOSE ARE ANY BIG SNAGS INVOLED
THAT I SHOULD BE AWARE OF?
