Prop extension
Prop extension
Hi all.
I am looking for a 3 or 4 inch prop extension , 6" diameter, SAE 2 hub, if
anyone has one that they want to part with..
Dale
Dale
Prop extension
Let me look on the shelf and will get right back to you Dale. Wayne
P.S. Sounds long if this is for your Rebel!
PSS - Anchor nuts arrive yet?
Sent: Monday, October 18, 2004 4:53 PM
Subject: Prop extension
ifHi all.
Dale
Prop extension
I have a 3 inch spacer as used on a Cherokee 180. $30.00
George Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Web Site www.gesoco.com
e-mail George@gesoco.com
Dale Kilbey
Sent: Monday, October 18, 2004 3:54 PM
Hi all.
Dale
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Dale Kilbey
Hi all.
Dale
Prop extension
Dale...I have two for Sensenich props (can use on anything by not using the
dowel pins). One is brand new - 2 1/4" thick x 6" dia. Other is lightly
used - 2 11/16" thick x 6" dia. Both are drilled for 7/16" bolts (like would
be on an E2D and a few other O-320's) in SAE #2 pattern for Lycoming. Little
short of the size you want...but I've heard that complaint before !
ifHi all.
Dale
Prop extension
Hi Dale, I believe the sae 2 is the heavy flange with the indexing lug
correct? If so I believe I have one if Wayne dosen't. I'll verify the length. but
I think it's 4". Curt N97MR
Prop extension
Curt..SAE #2 is a 4 3/4" diameter bolt hole circle as found on 98% of the
lycomings(a couple of O-235's are SAE #1) and SAE #1 is 4 3/8" diameter bolt
circle as found on most continentals.
The one thing Dale needs to add to his request is what motor it's for. I am
assuming O-235 or O-320... so he needs an extension with the lug holes
counter bored to 5/8" diameter..where as an O-360 has lug holes that are
3/4" diameter.
Sent: Monday, October 18, 2004 6:13 PM
Subject: Re: Prop extension
3/4" diameter.
length. butHi Dale, I believe the sae 2 is the heavy flange with the indexing lug
Prop extension
Also, the indexing lug is strictly for the flywheel. The oversize portion of
the lug only comes out for the thickness of the flywheel in order to locate
it's timing marks correctly. Propellor/spacer can be installed in any
position...although to be correct, for a 2 blade prop, it should be stopping
in the ready to hand swing position.
Prop extension
Hi Wayne , Curt and George
I'm using a Subaru 2.2 with a PSRU. The prop flange is 6" diameter wtth
43/4" diameter bolt pattern as Wayne said. The holes in the flange are 5/8'
with drive lugs with 3/8" bolt holes, non threaded. Prop is a 72" three
blade Warp Drive.
That is correct Wayne . It's for my Rebel. I am fabricating a cowling
similar to your four hinge model and have to move the nose bowl forward to
clear the engine.2" would help, but three or four would be better.
Lugs are probably in the mail box. Didn't check it yesterday
Dale
blade Warp Drive.
Dale
Prop extension
Hi Dale
What psru? I have the short 200 hp Marcotte psru on that engine. I was
sure that I'd need a prop extension but when I actually made the
nosebowl I found that I did not. There is not a lot of clearance from
the starter but I didn't even need a bump in the nosebowl like for a
Lycoming starter. The Marcotte is designed for a manual transmission
starter which might be a fraction of an inch shorter than the one off
the automatic. The starters that I've seen are not easilly
interchangeable but I can measure the length of both if it helps.
blade Warp Drive.
Dale
Prop extension
The spacer I have has 43/8 diameter hole pattern and is 5 3/8 in overall
diameter. It has two dowel pins on one side and matching holes on the other
side. I guess it will not work for you.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Dale Kilbey
Sent: Tuesday, October 19, 2004 9:20 AM
blade Warp Drive.
Dale
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Dale Kilbey
blade Warp Drive.
Dale
Prop extension
Hi Dale !
Which nosebowl are you using - the MAM one, or the Thorp T-18
from A-S, or one of your own ??
blade Warp Drive.
Dale
Prop extension
Thanks Ken but I am using a belt reduction unit. I attatched the plywood
discs and trimmed the nosebowl for the starter but am still too close. I am
using the Thorpe T-18 nosebowl from AC Spruce Bob.
Wayne , I wasn't clear whether the ones you had would fit. I could set up a
juig and see if 2 11/16 would work.
Dale
Dale
Prop extension
Mine have bolt holes for 7/16" bolts Dale. Wayne
Sent: Friday, October 22, 2004 11:07 AM
amThanks Ken but I am using a belt reduction unit. I attatched the plywood
ausing the Thorpe T-18 nosebowl from AC Spruce Bob.
Dale
Prop extension
Thanks Wayne.I guess it's AC Spruce.I received the lugs.
Dale
Dale
Prop extension
Curt had something? and it probably had 3/8" bolts. Curt did you confirm
what you had?
Sent: Saturday, October 23, 2004 1:31 AM
what you had?
Dale
