Up elevator rigging
Scott Aldrich
Up elevator rigging
Post by Scott Aldrich » Sat Feb 18, 2012 9:31 am
Rick, I think you were probably asking more about the tail buckling..
but if it is the elevator throw there was a discussion awhile back about
the throw on the SR/Moose. Brian at MAM said they used 20 degrees up and 15
degrees down elevator. 20 up seems like not enough. I can't find the post
from Steve on Ron's Moose up throw but it was 30 or more. They are not
running out of elevator and they have not had any problem with the elevator
stalling with the increased throw. This is all on floats.
The original Moose demonstrator didn't have much (any?) real stall break in
the only power off stalls I did. It just went into a steady decent. Some
will say, cool, gentle stall, but I thought more along the lines of not
enough elevator authority to reach critical angle of attack. More throw
would help arrest the high sink I have heard some getting on landings in
their Moose/SR's,(along with all the other possible ideas out there like
VG's on the wing and tail, cuffs, longer tips, etc.)
Finally to the point - to get considerably more throw on the Moose/SR we had
to elongate the tops of the holes in the bulkheads that the elevator pushrod
goes through or the tube hits/rubs on them. We added an oval inspection
hole in the bottom of the airplane aft of the elevator push rod below the
main cargo floor. We were able to remove the fast builds already installed
pushrod to work on the bulkhead holes by pulling it out the back (also added
a forward hole to be able to remove and install the front bolt.) I believe
that the bellcrank wanted to hit the bulkhead as it was pulled forward for
up elevator also so we made the bottom hole in that bulkhead slightly
larger.
I think with more throw guys will discover, like Murray did in his Rebel,
that the flare is less exciting.
FWIW
Scott
Moose 174
rickhm@comcast.net
Sent: Monday, September 20, 2004 2:16 PM
Subject: Re: UP Elevator rigging and Murray's (unfortunate) offroad
adventure!
Unfortunate! What airframe, Rebel or SR/Moose. My reason for asking is to
understand if all of us building a SR/Moose will see this.
Rick Muller
SR70
Forwarding for Murray ......as he has a Shaw bounce problem as well !!
Hello:
During rebuild after my accident I adjusted the elevator to give about 28*
up elevator which when the slack is taken out in flight is probably closer
to 25*. This makes a real difference when in the flair to land. My
landings
so far have been not bad but it is nice to have this extra up elevator.
Never knew what I didn't have until I re-rigged.BOB said he likes at least
26* up if I remember correctly. Just FWIW. And yes I am back in the air as
of today.
THE ACCIDENT
Landed at Int. peace Gardens border crossing to pass customs on the way
home
from OSH.(what a great place)My tail wheel stuck turning left. No amount
right rudder and brake would convince it to turn right. Left the runway
stopped after turning 190* and buckling the fus in front of the tail. All
the damage was contained to between the solid bulkhead and bulkhead "E".
The
release pin which allows the tail to free wheel had become burred as well
as
the round piece which it comes out of was also burred on the sides.This
jammed the wheel in a left turn position. I believe I"m not the first one
that this has happened too. Before you go flying again you might want to
take the tail wheel apart and have a good look. I filed my wheel into "G"
and have installed a Scott 3200.This is like day and night with an 8"
wheel
back there. It really feels good. I also added a dorsal fin which will
strengthen the tail section up a little also.
Good luck to all
Murray
List archives located at:
Ted Waltman
UP Elevator rigging
Post by Ted Waltman » Sat Feb 18, 2012 9:31 am
With 68 landings in my Moose, I can say that if one gets too slow on
final there's very little (if any) up elevator left for a flair/landing
fineness. This is particularly true with a (very) forward CG (e.g. full
fuel, pilot, no bags/other weight.
Adding some ballast to the baggage area when flying solo will help this
issue tremendously.
With about 600+ landings in a Maule prior to owning the Moose, I can say
that the Maule had the same issue--too slow on approach and you either
added power to flair or pancaked. Adding a bit of up elevator will, of
course, help a little. However, it would be my humble opinion that the
right approach speed is really the key.
rickhm@comcast.net
adventure!
to understand if all of us building a SR/Moose will see this.
Rick Muller
SR70
Dick Shotwell
UP Elevator rigging
Post by Dick Shotwell » Sat Feb 18, 2012 9:31 am
Ted,
What approach speed do you use? We have about 50 hours on Moose 235DS and
have had our best landings with an approach speed of 90 MPH indicated (no
flaps). This seems too high but at the same time seems to work well. We
are still experimenting. We've made some pretty bad landings using full
flaps and 75 MPH (indicated) approach speeds.
Still testing!
Dick
Sent: Monday, September 20, 2004 18:22 PM
Subject: RE: UP Elevator rigging
issue tremendously.
rickhm@comcast.net
adventure!
Rick Muller
SR70
Scott Aldrich
UP Elevator rigging
Ted, I agree, correct approach speed is key. I just want to fart around with
everything I can to reduce the stall speed so that the correct speed is as
slow as possible. IF the inability to get much flare at the lower speeds is
due to insufficient tail authority to increase the wings angle of attack I
want "fix" that too.
I believe your up throw was about 24 degrees. If Brent put in the standard
elevator stops you only have to remove one screw to take out the half round
to file the back off a little, or use a different one to not mess up the
original. Not suggesting you do that but it is a possibility if you wanted
to see what more throw does.
What kind of a stall break do you get in power off stalls at altitude?
Flaps and no flaps?
Scott
Waltman
Sent: Monday, September 20, 2004 6:22 PM
issue tremendously.
rickhm@comcast.net
adventure!
Rick Muller
SR70
Scott Aldrich
UP Elevator rigging
Dick, did I already ask what your elevator throw was?? In degrees or inches
up at the trailing edge?
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dick
Shotwell
Sent: Monday, September 20, 2004 7:22 PM
Ted,
Still testing!
Dick
issue tremendously.
rickhm@comcast.net
adventure!
Rick Muller
SR70
Dick Shotwell
UP Elevator rigging
Hi Scott,
No and I can't remember but will check and let you know.
Dick
Sent: Monday, September 20, 2004 19:38 PM
inches
Scott
Shotwell
Ted,
Still testing!
Dick
issue tremendously.
rickhm@comcast.net
adventure!
Rick Muller
SR70
Legeorgen
UP Elevator rigging
Post by Legeorgen » Sat Feb 18, 2012 9:31 am
Dick,
90 MPH is to high of an approach speed. A good place to start would be your
stall speed (set up for landing) X 1.3. Get up to a safe altitude and fly right
on the edge of stall, practicing turns, etc., for a half hour straight. Just
hang it on the edge until you have a real good feel for the plane. Then go
practice your landings.
Bruce
rickhm
Up elevator rigging
Post by rickhm » Sat Feb 18, 2012 9:31 am
Thanks for the info. Very helpful and you did clarify some questions I had. BUT, I was actually asking about/thinking about the tail wheel issues and wondering if the SR/Moose was at risk as outlined in the misshap you forwarded. Has there been an issue with the SR/Moose tail wheel locking up?
Rick
SR70
larger.
FWIW
Scott
Moose 174
rickhm@comcast.net
adventure!
Rick Muller
SR70
Hello:
landings
of today.
THE ACCIDENT
home
The
as
wheel
Good luck to all
Murray
Ted Waltman
UP Elevator rigging
I don't get much (if any) of a break, regardless of whether it is power-of f of half-power, in a stall. I haven't had the guts to put full-power on and try a stall, as the deck angle is just way to high for my taste (so far anyway). The plane just mushes with about a 800fpm descent rate.
I have tremendous respect for your insight and desire to experiment with the elevator rigging. I have about 5 other items to "fix" on my plane and then, perhaps, I'll get to changing the rigging to see what happens. Thanks for the tips.
From: mike.davis@dcsol.com on behalf of Scott Aldrich
Sent: Mon 9/20/2004 7:35 PM
Cc:
Flaps and no flaps?
Scott
Waltman
issue tremendously.
rickhm@comcast.net
adventure!
Rick Muller
SR70
