The below link DOES work; all one has to do, depending on which email
client you're using, is insure that you have a complete link which you
click on or paste into your browser. Using Microsoft Outlook, I had to
simply "Edit" the message to get a one line link out of the two lines
that Outlook originally broke the link into.
It cut off some of the link to the article in the last one.
See if this works.
http://members.eaa.org/home/homebuilder ... /Homebuilt%
20Sc
rutiny_%20A%20guide%20to%20homebuilt%20inspections.html#TopOfPage
FAA inspections: URL
Thanks Ted.
Scott
Waltman
Sent: Sunday, September 12, 2004 11:05 AM
Subject: RE: FAA inspections: URL
See if this works.
20Sc
Scott
Waltman
See if this works.
20Sc
