Spinners
Spinners
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:27 am
Yes Clay, I still represent UHS. 10"& 12" work well with the nose bowl and
doors cowling and the 14" is just slightly bigger than you'd want on the
speed cowling. This is where VAN's 13" would be perfect.
Sent: Wednesday, September 08, 2004 7:25 PM
Subject: Spinners
Dale, can you tell me which spinner you bought from ACS. There's so
many to choose from.
Wayne, I believe that you were selling a fiberglass spinner a while
back. Do you still sell them? Can you give me some info.
Thanks guys.
Clay
List archives located at:
Clay Smith
Spinners
Post by Clay Smith » Sat Feb 18, 2012 9:27 am
Thanks guys.
Clay
rebel
Spinners
Post by rebel » Sat Feb 18, 2012 9:27 am
I used the UHS 12 incher with the speed cowl when I had the Warp prop. Very
easy to fit and install compared to my current one from MAM for the
Sensenich. It looks a little flimsy compared to the metal ones, but seemed
to work fine. I made sure the whole assembly, prop, spinner and bolts were
perfectly balanced. I don't think it would hold together long if it ever
cracked.
"Wayne G. O'Shea" <oifa@irishfield.on.ca> wrote in message
news:012201c49611$4dce4270$e401910a@celeron266a...
Subject: Spinners
Thanks guys.
Clay
Clay Smith
Spinners
Post by Clay Smith » Sat Feb 18, 2012 10:12 am
Hi Guys,
I've decided on buying a metal (probabaly pre-polished) spinner. ACS
has a number of metal spinners but it seems to me that the SN-5 at 12"
in diameter and 11 1/8" long is the right one to buy. There is a longer
BN-3 spinner that apparently requires a front bulkhead, but the prop
thickness selections they offer won't suit my prop. Any thoughts on
this? Has anyone tried polishing their own?
Clay
Reb460
Spinners
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:12 am
Depends which cowling you are going with. The "speed" cowling needs a 13"
spinner to look correct. A 12" works nice with the "piper" nose bowl cowl.
Sent: Sunday, February 20, 2005 7:37 PM
Subject: Spinners
Hi Guys,
Clay
Reb460
rognal
Spinners
Post by rognal » Sat Feb 18, 2012 10:13 am
Clay,
A tale of my experience with ACS Products Co. (subsidiary of Aircraft Spruce):
I have a Sensenich wood prop to install on my Rebel. In June of '04 I placed
an order to Aircraft Spruce for a BN-3 Spinner Kit (12"D x 13 1/4"L) which
Charley Denney at Sensenich had recommended. The BN-3 has both a front and
rear bulkhead.
It takes about 8-10 weeks for ACS Products Co. to manufacture the kit. When I
finally received it, it was badly damaged. The box had been crushed at one
end. The box was just barely big enough for the major diameter of the spinner
so the packing peanuts were of no help. A call to Aircraft Spruce and they
arranged to have UPS pick it up and return it at no charge to me. All I had
to do was wait another 8-10 weeks for a new spinner to be built.
The new spinner arrived in good shape except the front bulkhead was of too
small a diameter, leaving nearly an inch of space between my prop face and
the front bulkhead. I placed a call to ACS Products directly and was told I
probably received the wrong size front bulkhead. They advised me to ship the
bulkhead back (my expense)and they would ship me the correct size.
Approximately 4-6 weeks later I received the new front bulkhead. It was
exactly the same size as the one I had returned!
At this point I was getting pretty pissed off at ACS Products. I placed a
call to Aircraft Spruce Customer Service, told them my problem, asked them to
refund or replace the BN-3 with a BN-2 (10 3/4"D x 10"L and only one rear
bulkhead!).
Aircraft Spruce was very cooperative, gave me a return authorization to
return the BN-3 spinner kit (my expense, again), subsequently credited my
money back to my account, at which time I (very reluctantly) placed an order
for the BN-2 spinner kit.
Another 8-10 weeks to wait and I just recently received the BN-2 spinner,
nearly 8 months after I placed the original order. Consequently I have
nothing good to say about ACS Products Co. However, I know of no one else
that makes an aluminum spinner for experimental aircraft, so if metal is what
you want, it seems we are stuck with ACS Products.
I might also mention that with my 4D cowl (MC-3B nosebowl) the BN-3 was much
too long IMO, and made the aircraft look like it had a 'Jimmy Durante' nose.
Just FYI. Hope it helps.
Roger Hoffman #687R
Eugene, OR USA!
Spinners
Post by Walter Klatt » Sat Feb 18, 2012 10:13 am
Why not just go with the 13 inch spinner from MAM? That's what I
used, and it took a bit of time and care to install, but it
worked out great for me. They can be polished too if you want.
There has been a lot of experience with these on the list if you
want to search the archives. You do have to drill the holes in
the bulkheads with these, and it helps if you know a machinist to
get it right. Also, the blade cut-outs take a bit of work. But if
you can build a plane, this is still a minor challenge.
rognal@dcsol.com
Sent: Sunday, February 20, 2005 10:50 PM
Subject: Re: Spinners
Clay,
rear bulkhead.
been crushed at one
be built.
bulkhead was of too
correct size.
bulkhead. It was
bulkhead!).
authorization to
Consequently I have
know of no one else
Roger Hoffman #687R
Eugene, OR USA!
K. Oliver
Spinners
Post by K. Oliver » Sat Feb 18, 2012 10:13 am
I took the easy way out
Prop, spinner, Bolts all from sensenich
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Monday, February 21, 2005 9:46 AM
Subject: RE: Spinners
rognal@dcsol.com
Clay,
rear bulkhead.
been crushed at one
be built.
bulkhead was of too
correct size.
bulkhead. It was
bulkhead!).
authorization to
Consequently I have
know of no one else
Roger Hoffman #687R
Eugene, OR USA!
Clay Smith
Spinners
Post by Clay Smith » Sat Feb 18, 2012 10:13 am
Hi Roger,
I'm sorry to hear about your bad experience with ACS. So far, I haven't had
any problems like that with ACS but I have had my share of problems with
other vendors. Maybe I'll order my spinner and arrange to pick it up at Sun
n Fun. I do have the piper nosebowl and like Wayne, I think that the 12"
diameter would look good. Does anyone have the 13" diameter on this
nosebowl? .
Wayne, what would it cost me for one of your fiberglass spinners?
Clay
Sent: Monday, February 21, 2005 3:19 AM
Clay,
Spruce):
placed
rear bulkhead.
When I
spinner
had
bulkhead!).
order
what
much
nose.
Roger Hoffman #687R
Eugene, OR USA!
Spinners
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:13 am
Clay, I will send you a picture of MAM's 13" on the "piper" nosebowl and UHS
fiberglass pricing direct. This is what is on FOKM that Garry bought from
me.
10" works on the piper nosebowl, but 12" would look better and pretty much
give a "clean" transition at the top to cowl deck.
Sent: Monday, February 21, 2005 7:01 PM
Hi Roger,
had
Sun
nosebowl? .
Clay
Clay,
Spruce):
placed
which
rear bulkhead.
When I
one
spinner
they
had
too
told
them
rear
bulkhead!).
my
order
spinner,
else
what
much
nose.
Roger Hoffman #687R
Eugene, OR USA!
Clay Smith
Spinners
Thanks Wayne for getting back to me so soon. I agree, the 12" does have a
kind of blunt look to it. Too bad. FOKM's spinner does look good (I didn't
realize that was a metal 13") So it's only available from MAM? I have seen
an old metal 12" by 11 1/2" long that looks good but the guy can't remember
where he bought it from.
This shouldn't be so difficult.
Thanks again for your help.
Clay
P.S I know that this is probably more of a nuisance than anything for you,
but do you still sell those pog nylon washers that fit between the control
surface hinge points?
Sent: Monday, February 21, 2005 8:56 PM
UHS
me.
Hi Roger,
had
Sun
12"
nosebowl? .
Clay
Clay,
Spruce):
placed
which
rear bulkhead.
When I
one
spinner
they
had
too
told
ship
was
placed
them
rear
bulkhead!).
my
order
spinner,
else
is
what
was
much
nose.
Roger Hoffman #687R
Eugene, OR USA!
Spinners
As Keith said..Sensenich sells some nice ones direct to fit their
props..precut and ready to go!
As for the nylon thrust washers ..."pogs"..YES still have 1/2 a box full.
Send me $5 in an envelope with your address etc and I'll send you a dozen
the same way. You just need to cut a flat bottomed V out of them with side
cutters to clear the safety tie bolt.
Wayne O'Shea
1516 Alvin Williams Rd
Penetang, Ontario
L9M 2C1
Sent: Monday, February 21, 2005 9:40 PM
didn't
seen
remember
Clay
you,
UHS
from
me.
much
Hi Roger,
haven't
had
with
at
Sun
12"
nosebowl? .
Clay
Aircraft
Spruce):
placed
which
front
kit.
When I
at
one
spinner
they
All
had
too
face
told
ship
was
placed
asked
them
rear
credited
my
an
order
spinner,
have
else
metal
is
what
was
much
Durante'
nose.
Garry Wright
Spinners
Post by Garry Wright » Sat Feb 18, 2012 10:13 am
On the subject of spinners I know that Cessna declares the spinner to be
an airworthiness item on their line of singles. ie: no spinner, no fly.
Anyone know why?
Garry Wright
068R Amphib C-FOKM
403 931 1573
wrightdg@ca.inter.net
Wayne O'Shea
Penetang, Ontario
L9M 2C1
didn't
seen
remember
Clay
you,
UHS
from
me.
much
haven't
had
with
at
Sun
12"
Aircraft
which
front
kit.
at
one
they
All
too
face
and told
ship
was
placed
asked
them rear
credited
my
an
spinner,
have
else
metal
is
was
Durante'
spinners
Post by Ralph Baker » Sat Feb 18, 2012 10:16 am
Clay,
If you are using the "speed cowl" it seems to me that any spinner that
leaves a gap between the spinner edge to the cowl intake will require
the air passing down the side of the spinner to "bounce" off the flat
face of the cowl creating turbulence at the intakes and restricting the
flow of incoming air. On our speed cowl that requires a full 13"
diameter.
We elected to go with the Van's fiberglass spinner for ease of
installation. You can see exactly where to drill and the bulkheads are
fitted to the Sensenich prop thickness.
british thunder
spinners
Post by british thunder » Sat Feb 18, 2012 10:16 am
Clay
Not sure where you are, but I have had good luck getting spinners from UHS.
They are fibreglass and usually ships the next day balanced and all hardware
included.
905 640 1534
I think Wayne sells them as well.
Sent: Wednesday, March 09, 2005 8:53 AM
Subject: spinners
Clay,
diameter.
