No this is not SPAM for pitot tube enlargement.
Does the diameter of the pitot and static hook up lines really matter? I
want to use a fairly small diameter to get through a tight spot. It seems
to me that since it is just pressure it really shouldn't matter what size
they are?? Yes, no, thoughts?
Scott
Moose 174
Does size really matter?
Hi Scott !
You ARE running the lines down inside the wing strut AREN'T YOU !??
It's MUCH easier to hook up that way ....
I wouldn't want to go any smaller diameter than what's needed to
connect to the instrument (1/4" ??) - probably not good to go small &
then large again. The pressures we're measuring are pretty small,
and I would think wall friction could be a factor in a very small tube.
Technically, you're right - the pressure will equalize - but there could
be an unacceptable delay while this happens. ;-) :-)
Static is particulary sensitive to this effect.
I have had good results going from 5/16" at the pitot, down to 1/4"
inside .... but not smaller, and never up in diameter again.
Scott
Moose 174
Scott - There was some good discussion about the same thing relative to "ram
air" pressurization of the fuel tank vents - I thing that pressure drop is
not an issue if there is no flow -
Britt SR194
Hi Scott !
Britt SR194
Hi Scott !
Scott
Moose 174
I wasn't planning on the wing strut route but I may have to consider that.
On mine there is a space above the strut attach point that looks like the
hose would fit through.
Scott
Patterson
Sent: Wednesday, September 01, 2004 9:31 AM
Subject: Re: Does size really matter?
Hi Scott !
Scott
Patterson
Hi Scott !
Scott
Moose 174
Hi Scott !
There are several reasons for running wiring & plumbing down
the wing strut - the best is that everything then enters the fuselage at
the bottom side, and is easy to run up behind the panel. There's NO
easy way to get wiring, etc. DOWN from the wing root to behind
the panel .... All you need are quick-connects at both ends of the
strut, for easy de-rigging (these are available for pitot lines from
most glider supply houses, and trailer connectors will do for electric).
Just a suggestion - hope it helps .... :-)
Scott
Patterson
Hi Scott !
On Wednesday 01 September 2004 11:10 am, Scott Aldrich wrote:No this is not SPAM for pitot tube enlargement.
Scott
Moose 174
