Hi All
I've just uploaded an excel spreadsheet produced from an article in SPA's
Water Flying July/Aug 2004 by Paul Armstrong which is based around a formula
from EDO and Leon Kaplan.
Simply enter engine HP, total float buoyancy, wing area, MTOW, and prop type
in the blue area's and it comes up with a time on the water.
I've had to upload it to Elite/float installations as I cannot get it to go
into the software section (Mike...could you sort this for me when you get a
chance please ?)
Comments please only about the accuracy of the equation - NOT about my
skills with Excel :-)
Nigel
Elite 745E
Time to Takeoff for float planes
The times seem a little optimistic for mine. If I'm lightly
loaded at 1600 pounds, it says my take-off time should be 4
seconds. I have never seen that, even with a strong wind. Also, I
noticed that the higher the floatation buoyancy, the shorter the
take-off times. At some point the bigger floats would have more
drag, which does not seem to be taken into consideration.
Maybe the formulas are designed around a specific airplane and
float, like a 185 on EDO's?
N.Smith
Sent: Tuesday, August 10, 2004 1:26 AM
Subject: Time to Takeoff for float planes
Hi All
an article in SPA's
chance please ?)
Nigel
Elite 745E
I saw this article in SPA magazine for float take off times too and plugged
in my own numbers (same as yours Walter) for gross weight and It showed a take
off time of 26 seconds, if I remember right.
I have not seen the formula Nigel posted but I would guess you either
miscalculated or the formula was not copied correctly.
I believe it was intended for a rough estimate as it did not take into
consideration the pitch of the prop if it was a fixed pitch blade. But they did say
it was accurate with most aircraft.
Bruce
Bruce
At 1730 gross weight and 3500 (2 X 1750), I get 7.5 seconds,
which is a little fast, even for my little water rocket.
Legeorgen@aol.com
Sent: Tuesday, August 10, 2004 4:25 PM
Subject: Re: Time to Takeoff for float planes
guess you either
did not take into
Bruce
