oil cooler location
Andy Bowman
oil cooler location
Post by Andy Bowman » Sat Feb 18, 2012 9:22 am
hi Angus,
we added an oil cooler and then changed it's ductwork/location 4 times.
we went from nothing to firewall with 2 inch scat from left rear
baffle. then to 3 inch from left baffle. next was right rear baffel
mount for the cooler. last, and so far successful, was left front air
inlet lower ramped baffle for the cooler location. we were breaking in
our overhauled 0-320 during this period, but i think you can't possibly
get enough air through a 3 inch scat to do the job. get the cooler in
the airflow and infront of the heat source has got to be better than
aft.
good luck. don't give up because there is a solution for your
particular set up waiting for you to find it.
andy
christavia mk-1 currently being placed on 1800 amphibs.
__________________________________
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
mike jones
oil cooler location
Post by mike jones » Sun Feb 19, 2012 11:38 am
Hi all
How close can oil cooler be the the conical engine mount, gusee what I want
to know is how much does the engine mount move when engine is running at the
attachment point
Mike#007
