Moose ideas and parts sourcing
Dear Fellow Moose Builders,
Your guidence and reccomendations are highly regarded and appreciated:
#1 Air Start System- I ordered my air start FWF kit from Kimball and I would
like the groups reccomendation on the best setup to have a primary and back up
air bottle system. Can anyone direct me to a source for a large (3000 psi +)
light weight air bottle? Any thoughts on the system?
#2 Gas door spring- Does anyone have a good source for a gas spring to open
and hold Moose doors? The only one i found was at www.mtnviewaviation.com and
they are expensive.
#3 Inertia reel harness- Has anyone installed and made the modification for
an overhead inertia real harness system. Check out www.basinc-acromod.com for
an example of an STC approved system for Cessna. I think It would be a
fantastic safety and convenience modification for the Moose.
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
Estimated Completion Date 2005
they are expensive.
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
Re- #2 The gas springs (shocks) are basically the same as what you
would find on the hatchback of your car, just in different lengths and
pressures. I did a project on a boat that needed the lifts and went to
my local parts store and my friend there was able to look up listings
for them in
1-closed length
2-open length
3-strength (or pressure).
I was able to find the right length within 1/2 inch and did have to try
a couple different pressures to get what I wanted. I was also able to
buy the brackets to mount them with as well. Didn't cost allot either.
You will have to probably go to a true "auto parts store" where the guys
(and gals) are a little more knowledgeable and know how to look these
things up. Usually they just look them up using car make model etc. But
if you go to the right place they should be able to help. Also a another
friend was able to pick up a set for something else from one of the
surplus stores we have locally. The selection wasn't great but he only
paid $2.50 a shock!
Sent: Tuesday, July 20, 2004 11:11 PM
Subject: Moose ideas and parts sourcing
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
for them in
1-closed length
2-open length
paid $2.50 a shock!
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
For number 2: Check out http://www.mcmaster.com/, catalog pages 1060-1063
for gas springs. They come in all sizes and pressures. I was able to find
a better than original for my a clam shell 340 door for about 1/4 of the
aviation model (not legal on Cessna but OK for homebuilt). Unit was
adjustable, sturdier, and works better than the original.
Brent
088 Moose
Brent
088 Moose
back up
open
they are expensive.
for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
Hi A,
I'll respond to two of your questions. I've gotta ask why you want a large
3000+ psi cylinder. Industry standard is 3AA2400 for 300 cubic ft.
cylinders. If you're talking about this large a cylinder (10" diameter x
60" tall) you're wanting this as a ground based recharge cylinder. You
should be able to get one of these locally from any welding supply
distributor. Some won't sell their own cylinders (I won't, for instance...)
but can order one for you that'll be a generic cylinder without ownership
markings. Expect to pay about $240.00 for such. If you INSIST on pressure
in excess of 3000 psi, such are available. Price will come close to $500
for a 3600 psi cylinder. Expect to pay $1000 for a 6000 psi cylinder. If
you do get one of these high pressure cylinders, you're gonna pay dearly to
have it filled to the pressure rating. Bottom line; get a standard 3AA
2400 size 300 cyinder. Make sure you tell your supplier that it's for
industrial air (valve CGA590) and NOT nitrogen.
I've bought several lift struts at Auto Zone. Check the length and end
configuration that you need and look through their display. They've
probably got 40 different styles. Prices are good, too.
Bill Delcambre
SR172FB
Sent: Wednesday, July 21, 2004 1:11 AM
Bill Delcambre
SR172FB
wouldDear Fellow Moose Builders,
back uplike the groups reccomendation on the best setup to have a primary and
+)air bottle system. Can anyone direct me to a source for a large (3000 psi
openlight weight air bottle? Any thoughts on the system?
andand hold Moose doors? The only one i found was at www.mtnviewaviation.com
forthey are expensive.
foran overhead inertia real harness system. Check out www.basinc-acromod.com
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
Getting the air bottle off the firewall sure makes it cleaner up there and
helps with wt & balance. We put ours (Kimball type bottle) aft of the
extended baggage compartment. Others have put smaller diameter bottles in
the floor under the front seats. We also moved all the solenoids to under
the seat to keep them out of the oil etc. We didn't put in a back up
bottle.
If you are talking Seaplane style doors with hinge at top. We got our gas
from Austin Hardware. http://www.austinhardware.com/default.asp?
The 90# seem to be working well. Undecided as to the best end fittings,
metal or nylon. My nylon ones seem to be good unless you take them on and
off a lot during testing. The little tabs inside break. I had to order all
new ends before I was done. I think someone told me the metal ends seemed
like you could tug them off the stud if someone accidentally pulled on them
too hard.
This is the one we used:
AVM 87-90 PE
Price: $13.96 EA
Weight: 0.8 lbs
(A) Extended Length 19.63"
(B) Compr. Length 12.63"
(C) Shaft Dia. 8mm
(D) Tube Dia. 19mm
(S) Stroke 7.00
Type of Connector PS130
Take care,
Scott, Moose 174, No longer estimating a completion date...
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
bottle.
too hard.
AVM 87-90 PE
Price: $13.96 EA
Weight: 0.8 lbs
(C) Shaft Dia. 8mm
(D) Tube Dia. 19mm
(S) Stroke 7.00
Take care,
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
-------- Forwarded Message ---------
Original: DATE..... 7/22/2004 8:38 PM
Original: FROM..... SA@MWUTAH.COM
Original: TO....... REBEL-BUILDERS
Original: SUBJECT.. RE: Moose ideas and parts sourcing
Original: FORUM.... Rebel Builders
Forwarded By....... REBEL on 7/30/2004 7:59 PM
Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.1)
for rebel-builders@dcsol.com; Thu, 22 Jul 2004 20:38:43 -0800
Received: from mail.mwutah.com ([208.186.255.2]) EHLO=mail.mwutah.com
by dcsol.com (Wildcat! SMTP v6.0.451.1) with SMTP
id 563795406; Thu, 22 Jul 2004 20:38:40 -0800
Received: from localhost (localhost [127.0.0.1])
by mail.mwutah.com (mwutah.com) with ESMTP id 51783140136
for <rebel-builders@dcsol.com>; Thu, 22 Jul 2004 22:38:06 -0600 (MDT)
Received: from mail.mwutah.com ([127.0.0.1])
by localhost (brother [127.0.0.1]) (amavisd-new, port 10024)
with ESMTP id 21409-10 for <rebel-builders@dcsol.com>;
Thu, 22 Jul 2004 22:37:58 -0600 (MDT)
Received: from LEERE (unknown [208.186.255.7])
by mail.mwutah.com (mwutah.com) with ESMTP id 933A8140130
for <rebel-builders@dcsol.com>; Thu, 22 Jul 2004 22:37:57 -0600 (MDT)
Subject: RE: Moose ideas and parts sourcing
Date: Thu, 22 Jul 2004 22:38:26 -0600
X-Orig-MIME-Version: 1.0
X-Orig-Content-Type: text/plain; charset="us-ascii"
X-Orig-Content-Transfer-Encoding: 7bit
X-Mailer: Microsoft Office Outlook, Build 11.0.5510
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1441
In-Reply-To: <001701c46eee$86c13fa0$b4b874ce@bc.hsia.telus.net>
Thread-Index: AcRu7iVIa0KtzB6zSDSA9px8xS3IDwBeawQg
Message-Id: <20040723043757.933A8140130@mail.mwutah.com>
X-Virus-Scanned: by amavisd-new-20030616-p9 (Debian) at example.com
X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
bottle.
too hard.
AVM 87-90 PE
Price: $13.96 EA
Weight: 0.8 lbs
(C) Shaft Dia. 8mm
(D) Tube Dia. 19mm
(S) Stroke 7.00
Take care,
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
----- End of Forwarded Message -----
bottle.
too hard.
AVM 87-90 PE
Price: $13.96 EA
Weight: 0.8 lbs
(C) Shaft Dia. 8mm
(D) Tube Dia. 19mm
(S) Stroke 7.00
Take care,
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
For a large airstart bottle, I have a few 3000 psi aluminum scuba bottles.
These are new and never been used. $125 each. I believe most of them are
either gray or flouresent yellow
Bobby
Bobby
allGetting the air bottle off the firewall sure makes it cleaner up there and
bottle.
themnew ends before I was done. I think someone told me the metal ends seemed
too hard.
AVM 87-90 PE
Price: $13.96 EA
Weight: 0.8 lbs
(C) Shaft Dia. 8mm
(D) Tube Dia. 19mm
(S) Stroke 7.00
Take care,
I would
back up
psi +)
to open
they are expensive.
modification for
See you at OSH!
Regards,
A. Zeff
Moose 227 QB
Return Receipt
Your Re: Moose ideas and parts sourcing
document
was Bruce Uvanni/Burlington/IBM
received
by:
at: 08/02/2004 08:25:14
document
received
by:
