Just for the record. The 3 blade MT props for the M-14 come in three
recommended lengths 96", 102" and 108". The aerobatics guys tend to use the
108". The basic recommendation for floats was 102"
Regards,
Don B.
Hi Ted !
92 " sounds like a lot for a 3 blade on the Moose -
is that the diameter that Hartzell recommends ?? I seem to recall
that the 2 blade paddle was 9 feet - 108". Would have thought that
a 3 blade would be a lot shorter ...
In any case, there wasn't a big problem with clearance with
the 9 ft. paddle - although I was a bit nervous about raising the tail
too far the first few times ! ;-) So you should be fine with a
larger tailwheel.
