oxyport@globetrotter.net writes:
JEANTo contersink the end rib, I use the little Mam tool that woork fine
except.....at the end of the rib! There is not suffisant space between to run the
"nail".. How should I do it?
I bought an extra set of dimpling disc that you pull with a 6 penny nail,
like the ones supplied. And ground a flat spot on one side for those tight spots.
As long as you don't grind past the dimpling area you're good to go.
Phil&Lisa Smith
#460R
N414D
