Yokes
Warren Montgomery
Yokes
Post by Warren Montgomery » Sat Feb 18, 2012 8:55 am
Thanks Bobp
I think I'd test fly at full trim and if need be limit trim travel to
stay within control.
I'm using Chinese hat trim switches (elev/rudder) that I'll machine into
the top of my ACS control wheels. Will also configure with
a small PTT. May not have room for an AP instinctive disconnect though
so most probably will leave on panel (EFIS/One).
I understand other type builders have mounted a HOTAS grip on yoke by
cutting one side off but I want to keep them conventional.
Is anyone else going with Yokes?
Warren
Bob Patterson wrote:
Hi Warren !
That was the caution I was given .... and it applied to ALL of
the factory Supers and the Moose. Just passing it along, and I'm glad
to hear that most builders are incorporating some kind of easily-
accessible 'kill' switch or pull-out circuit breaker. Just don't
hesitate to pull it if in doubt - you won't have long !!
While I didn't try to fly any of them with full trim deflection,
I can imagine that you wouldn't be able to hold it off for very long if
it did go to full travel - that's a very powerful trim.
Also, be careful about button layout on the stick - there were
a few exciting moments when trim was hit instead of mike PTT on short
final - also when the right-seat pilot hit it accidentally with a camera !
I would never suggest putting the trim tab on the stick for ANY
Murphy kit except the SR/Moose - it certainly is NOT needed there
for the Rebel, as the trim is very seldom ever changed !!
This is just a heads-up - I have not personally ever heard of
one of the MAC servos going runaway - but, it <could> happen !
On Tuesday 27 January 2004 08:19 am, you wrote:
Bob,
Are you saying that with full runaway trim you can't override with elevator.
This would not be a failure tolerant system.
Warren
When choosing your button layout, make sure it's difficult to push
the trim by accident - more than a few exciting moments on short final
when the trim was pushed instead of press-to-talk !! Also, it would be
a good idea to have a separate pull-type breaker in an easy-to-reach
spot on the left side panel, for the trim motor - if it ever runs away in
the Moose, there's NO way you could hold it with the stick !!!
(only had ONE good scare - but that's one too many !)
