SR 2500 Gear
SR 2500 Gear
Post by Mike Davis » Fri Feb 17, 2012 5:19 pm
Received: from pmail.emirates.net.ae by omail.emirates.net.ae
(Sun Internet Mail Server sims.3.5.1999.01.13.19.49.p4)
with ESMTP id <0FBM00GIRAUA3R@omail.emirates.net.ae> for
murphy-rebel@dcsol.com; Wed, 12 May 1999 15:34:58 +0400 (GST)
Received: from emirates.net.ae (mdt010.emirates.net.ae)
by pmail.emirates.net.ae
with ESMTP id <0FBM00FE1AU8V3@pmail.emirates.net.ae> for
Date: Wed, 12 May 1999 14:03:59 +0400
From: "Warren T. Montgomery" <monty@emirates.net.ae>
Subject: Re: SR 2500 Gear
To: Murphy Rebel <murphy-rebel@dcsol.com>
Message-id: <3739520E.486F98CF@emirates.net.ae>
Organization: PCC
MIME-version: 1.0
X-Mailer: Mozilla 4.05 [en] (Win95; I)
Content-type: multipart/alternative;
boundary="------------7CFD4873CCE4092C0A86E96C"
References: <04010703707831@dcsol.com>
--------------7CFD4873CCE4092C0A86E96C
Grant,An M14P SR will only have 6" prop clearance. I was hoping to add a
couple of
inches to the legs, whack a couple off the prop and also maybe larger rims .
haven't unpacked the brackets so don't know what I'm up against but in
theory could
they not be lengthened?
The story on the gear legs for the SR-2500 is as follows..
The LG-300 main gear legs are used for both the trike and tail dragger
version of the aircraft. Different axle attachment blocks are used for
taildragger and the trike. but other than that everything else is the
same
just different locations. The LG-310 gear leg is the nose gear leg on
trike version of the aircraft. Yes it looks just like a main gear leg
but
its not.
The large castoring nose wheel set up is like a Rebel tail spring setup,
on
a much larger scale.
Grant
M.A.M.
Content-Type: text/html; charset=us-ascii
<HTML>
a couple of inches to the legs, whack a couple off the prop and also maybe
larger rims .&nbsp; I haven't unpacked the brackets so don't know what
I'm up against but in theory could they not be lengthened?
<BR>&nbsp;
<BLOCKQUOTE TYPE=CITE>
<PRE>The story on the gear legs for the SR-2500 is as follows..
&nbsp; The LG-300 main gear legs are used for both the trike and tail
dragger
&nbsp; version of the aircraft. Different axle attachment blocks are used
for
&nbsp; taildragger and the trike. but other than that everything else is the
same
&nbsp; just different locations.&nbsp; The LG-310 gear leg is the nose gear
leg on the
&nbsp; trike version of the aircraft. Yes it looks just like a main gear leg
but
&nbsp; its not.
&nbsp; The large castoring nose wheel set up is like a Rebel tail spring
setup, on
&nbsp; a much larger scale.
&nbsp; Grant
&nbsp; M.A.M.</PRE>
</BLOCKQUOTE>
&nbsp;</HTML>
--------------7CFD4873CCE4092C0A86E96C--
