bottom... I have just finish mines as per mam
instructions, there are gusset at each end but just on top(or on bottom if
my memory fail...), should I add some?
Jean
Rebel 747R
Sent: Thursday, January 22, 2004 11:53 AM
Subject: [AVIS-NOTICE] Re: Balancing metal flapperons
onToo add...when you get your alum off, make sure there are corner gussets
diagrameach end rib (top and bottom) between the rib and the main spar where the
"D" skin overlaps (if you have the manuals take a look at the parts
mayand you'll see what I mean). These make sure everything stays square and
fornot be there since the alum cover was doing this job nicely. Also before
covering make sure you roll the edges down on the "D" skin and all ribs
fabric.a nice fabric finish and less chance of the edges chafing though the
CeconiteWayne
Sent: Thursday, January 22, 2004 11:19 AM
Subject: Re: Balancing metal flapperons
PolyfiberProbably as smart a move as any. Make sure you follow the (Stit's)system from start to finish, with no magic potion short cuts. Or
someonestart to finish (but I hear Polyfiber bought out the STC for Ceconite so
maybe not available anymore--don't know). Seen to many times where
onthat is supposed to be a "professional" has used some magic concoction
mytofabric "that is better" (in their mind only) than using the poly
brush/polyspray base coats and the proper matching paint over top. Still
lots of AME's both sides of the borders that like to use half the poly
fibers system and then start shooting dope on it (that makes it continuechanceshrink after it shouldn't be). I'm sure if Steve Wittman had anotherhavehe would have followed the system start to finish :o(!
At least there's one good thing about all this....you at least alreadydoingyour airplane apart for a good going through. We could have thrown these
things at you after you had it all back together again!
Once you have the alum off you are looking at approx 24 hours of work to
glue and cover with fabric, shrink (don't tell your wife what you arewith her iron!), poly brush and the two or three coats of poly spray if
someonememory serves me right. If you've never done fabric before, see if
ittrylocal has a copy of the polyfiber video to view before you start. If notto track one down or even buy it with your supplies and when done with
fabric.donate it to a local RAA chapter or resell it on Ebay!
From: "Peter, Juliet, & Wanaao" <northofsixty@mac.com>
Sent: Thursday, January 22, 2004 12:26 AM
Thanks Wayne you are a real wealth of info. I'm sure everyone here
appreciates your help.
Bob suggested that I just remove the metal and cover with stits
coveredI think I would prefer to go lighter than heavier specially with your
comment on how much nicer it flies with the fabric flapperons.
Thanks again,
Peter
On Wednesday, January 21, 2004, at 01:17 PM, Wayne G. O'Shea wrote:
