Hi Guys
We are at the point to get serious about installing the plumbing for the
pitot/static and I am trying to figure out what size (ID) of line to run to the
pitot and static ports. I have seen some references to 1/4" tubing but the
orifice of both the static fitting which attaches to the side of the fuselage and
the pitot are not large, perhaps .125 for the pitot, smaller for the static and I
don't expect there is much flow to speak of so is there any good reason for the
1/4" tubing?
I was thinking about more like 1/8" ID in a polyurethane which would be light,
small and with the PU, impervious to just about anything (including our present
cold snap....but thats' another story).
Any thoughts? Would the 1/8" be too small?
elite583.cjb.net
David A. Ricker
Fall River, Nova Scotia
Canada
Pitot Line Size?
Pitot Line Size?
Bigger is better here Dave for loss of pressure over distance of pipe.
Although there is no actual air flow it still seems to work better with a
larger line. Certified airplanes generally have 1/4" alum line run through
them with rubber joiners at detach points. I would be afraid that if you
just used 1/8" line you would be VERY susceptible to freezing in the line
from any minor amounts of moisture. I generally use the same 1/4" Parker
parflex tube that MAM supplies for the brake lines. Seems to do the trick.
Sent: Saturday, January 10, 2004 4:27 PM
Subject: Pitot Line Size?
to theHi Guys
thepitot and static ports. I have seen some references to 1/4" tubing but
fuselage andorifice of both the static fitting which attaches to the side of the
static and Ithe pitot are not large, perhaps .125 for the pitot, smaller for the
for thedon't expect there is much flow to speak of so is there any good reason
light,1/4" tubing?
presentsmall and with the PU, impervious to just about anything (including our
*-------------------------------------------------------------------------*cold snap....but thats' another story).
elite583.cjb.net
David A. Ricker
Canada
Pitot Line Size?
Hi Guys
The pressure loss thing was exactly what I was thinking about but I couldn't
see how there would be much flow. Having said that I now can think of another
good reason to go with a larger and aluminum line and that is to make sure any
moisture will run down hill (wing dihedral) and not collect in the inevitable
dips that would form in any flexible lines and this time of the year freeze.
Think I will have another look at where I can put some solid lines.
I'll keep Ralph's suggestion about traps in static port locations in mind also.
Dave R
"Wayne G. O'Shea" wrote:
David A. Ricker
Canada
Dave R
--Bigger is better here Dave for loss of pressure over distance of pipe.
to theHi Guys
pitot/static and I am trying to figure out what size (ID) of line to runthepitot and static ports. I have seen some references to 1/4" tubing butfuselage andorifice of both the static fitting which attaches to the side of thestatic and Ithe pitot are not large, perhaps .125 for the pitot, smaller for thefor thedon't expect there is much flow to speak of so is there any good reasonlight,1/4" tubing?
I was thinking about more like 1/8" ID in a polyurethane which would bepresentsmall and with the PU, impervious to just about anything (including our*-------------------------------------------------------------------------*cold snap....but thats' another story).
elite583.cjb.net
David A. Ricker
Canada
David A. Ricker
Canada
