Received: (qmail 21950 invoked by uid 0); 5 May 1999 17:32:55 -0000
Message-ID: <19990505173255.21949.qmail@hotmail.com>
Received: from 159.19.166.38 by www.hotmail.com with HTTP;
Wed, 05 May 1999 10:32:54 PDT
X-Originating-IP: [159.19.166.38]
Subject: How Removable is 'Removable'?
Date: Wed, 05 May 1999 10:32:54 PDT
Mime-Version: 1.0
Content-type: text/plain; format=flowed;
The Rebel has emerged as a serious contender on my list of potential
aluminum butchery projects. Trailerability and off-airport storage are
requirements in my selection process (eliminating Vans, etc).
The Rebel literature describes the wing removal process as requiring 45-60
minutes for a two man crew, which would be a tolerable level of effort. I
was wondering if replacing/removing the wings for each flying session
(weekly, maybe?) was within the realm of reason, and if this was a common
practice or a considerable undertaking. Any comments from you
'been-there-done-that' listers would be most appreciated!
_______________________________________________________________
Get Free Email and Do More On The Web. Visit http://www.msn.com
Received: from dialup.voyager.co.nz (ts1p06.net.ashburton.voyager.co.nz
[203.21.25.170])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with SMTP id JAA18825
for <murphy-rebel@dcsol.com>; Thu, 6 May 1999 09:00:39 +1200 (NZST)
Message-ID: <001501be973a$5efeb240$aa1915cb@dialup.voyager.co.nz>
Subject: Re: How Removable is 'Removable'?
Date: Thu, 6 May 1999 09:00:48 +1200
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Removing the wings on a weekly basis in my opinion would not be a viable
option. It is a considerably big job.
The fuel would have to be drained, fairings removed, fuel pipes and wiring
disconnected, pitot and static lines removed, flaperons disconnected, etc.
Two people may be able to remove the wings in an hour or so, but replacing
them would be a different matter.
I have found I need at least three people to fit my wings back on as it is
very easy to bend the rear wing attach bracket if things dont line up as
planned. Fitting the front wing attach spacer washers can be a bit of a
drama.
I dont think this is an option.
Really neat aircraft though--------!!
Alister
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Thursday, May 06, 1999 5:45 AM
[203.21.25.170])
MIME-Version: 1.0
X-Priority: 3
drama.
Alister
Received: from earthlink.net (ip196.richmond8.va.pub-ip.psi.net
[38.30.130.196])
by harrier.prod.itd.earthlink.net (8.9.3/8.9.3) with ESMTP id OAA05219
for <murphy-rebel@dcsol.com>; Wed, 5 May 1999 14:52:49 -0700 (PDT)
Message-ID: <3730BD77.BF9D9093@earthlink.net>
Date: Wed, 05 May 1999 17:51:51 -0400
From: "James A. Remington" <jaremington@earthlink.net>
Reply-To: jaremington@earthlink.net
X-Mailer: Mozilla 4.51 [en] (Win95; U)
X-Accept-Language: en
MIME-Version: 1.0
References: <19990505173255.21949.qmail@hotmail.com>
Not common, not reasonable! Fuel in tanks, fuel lines, control lines, etc.
jar
Stephen Lanham wrote:
[38.30.130.196])
MIME-Version: 1.0
jar
Received: from RebelAir@aol.com (8029)
by imo29.mx.aol.com (IMOv20) id bPYEa15861
for <murphy-rebel@dcsol.com>; Thu, 6 May 1999 00:32:29 -0400 (EDT)
Message-ID: <d8ffc8f8.24627558@aol.com>
Date: Thu, 6 May 1999 00:32:24 EDT
MIME-Version: 1.0
X-Mailer: AOL 3.0.i for Windows 95 sub 19
Hi There
It sounds like the other folks agree this is not really a viable aircraft
for
your requirements. You would be better if with a Kitfox or even a Glastar
if
you do not mind the considerable weight and considerable $ penalties.
Brian #328R
MIME-Version: 1.0
Hi There
for
if
Brian #328R
Received: from default ([207.53.188.185]) by mail.Ritzcom.net
(Post.Office MTA v3.5.3 release 223 ID# 0-12345L500S10000V35)
with SMTP id net for <murphy-rebel@dcsol.com>;
Thu, 6 May 1999 18:50:12 -0700
Message-Id: <3.0.3.32.19990506184843.006a0d20@ritzcom.net>
X-Sender: coyote@ritzcom.net
X-Mailer: QUALCOMM Windows Eudora Pro Version 3.0.3 (32)
Date: Thu, 06 May 1999 18:48:43 -0700
In-Reply-To: <3731A683.4AB5ECE@earthlink.net>
References: <000101be9759$f197e620$14640a0a@tim-toshiba>
Mime-Version: 1.0
Did you follow the instructions that I had sent in the attachment? Just
deleting the Happy99 virus attachment will not delete it, you need to
follow the procedures. Let me know if you need the instructions again.
Michelle
coyote@ritzcom.net
Mime-Version: 1.0
Michelle
coyote@ritzcom.net
cameWish I had seen the warning about the happy99.exe before I opened it. It
myfrom a friend who probably didn't know he sent it. I have deleted it from
hard drive. Will that get rid of it?
jar
Received: from earthlink.net (ip247a.richmond6.va.pub-ip.psi.net
[38.30.108.247])
by hawk.prod.itd.earthlink.net (8.9.3/8.9.3) with ESMTP id XAA02543
for <murphy-rebel@dcsol.com>; Thu, 6 May 1999 23:30:19 -0700 (PDT)
Message-ID: <37328892.189CDF0A@earthlink.net>
Date: Fri, 07 May 1999 02:30:42 -0400
MIME-Version: 1.0
I didn't see the instructions until after I asked how to get rid of it. I
have
since followed the instructions and they worked fine. I tried to forward
you
letter with the attachment of instructions to the list of those I infected
but for
some reason the attachment came through as part of the letter and was just
junk.
How can I forward the instuctions to others?
jar
Coyote Flats Farms wrote:
[38.30.108.247])
MIME-Version: 1.0
have
you
but for
junk.
jar
from myDid you follow the instructions that I had sent in the attachment? Just
Michelle
coyote@ritzcom.net
cameWish I had seen the warning about the happy99.exe before I opened it. Itfrom a friend who probably didn't know he sent it. I have deleted it
jar
